Raiken1
- First Name
- Jordan
- Joined
- Jun 6, 2025
- Threads
- 6
- Messages
- 45
- Reaction score
- 28
- Location
- Charlotte NC
- Vehicle(s)
- 2025 Ranger Raptor
- Occupation
- Mechanical Engineer
The Ford collision center had my truck for a week and made some sort of tweak and touched the paint up. It had a paper thin gap when I picked it up. It moved within a couple days and I figured out that they barely tightened the top bolt. They believe that my fender was manufactured improperly and said that if this didn't work they would have to replace the whole fender. I would rather not do that if I can. Mine is touching at the top inside corner and lower outside corner at the same time. I did find that you can pull it out a little and add plastic shims around then tighten. The shims prevent the tightening of the bolts from pulling it in or up (Then remove the shims once tight). I have 1/32-1/16 gap on top now and a paper thin one on bottom so I just slid a small piece of ppf at the rub point.
