RC MUSTANG Azure Gray Raptor Build
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
From yoiur pictures it looks like a straight shot right to the filter. Nothing like the factory setup. What am I missing? And what is this pre filter?
If you look at your truck the air comes up from the grille before it goes into the filter. Google pre filters for air filters. They've been around for years.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Wait, it goes in and then down into the box then up into the filter.
It goes up from the grille before it enters the air box. There's no straight shot into the filter unless you're driving around with no hood.
Ford Ranger RC MUSTANG Azure Gray Raptor Build Screenshot_20260301_063410_Gallery
Bt_okst
BT
Ok/Colo
Reused the billet pedal covers from my 2019. They don't fit 100% exact but I'll see how they hold on.
Signature lux has these for the 24+ ranger. They install easily and fit perfectly.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260217_171922
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
I prefer mine. They look like the factory ones on my Fusion and I haven't had any issues with them being loose while driving. And when I referred to the fit it was only the brake pedal that wasn't super tight. In no way do i mean they're going to fall off.
Bt_okst
BT
Ok/Colo
Understand, just letting others know there are options. Yours look great
some_guy
some
florida
entrepreneur
Compressor mounted. Air chuck outlet installed. Need to fabricate new mounting brackets for the tank and connect the hoses. Wired up.
What compressor and train horn are you using and where are they mounted? Can you do a detail post for these?
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
This is the original compressor setup.
VIAIR 150 PSI High-Flow Air... https://www.amazon.com/dp/B000X9LTXA?ref=ppx_pop_mob_ap_share
This replaced the original Viair pump that died and is actually more efficient.
DICMIC 12V 444C 200 PSI Chrome... https://www.amazon.com/dp/B0BZ4CL921?ref=ppx_pop_mob_ap_share
These are the horns.
Vixen Horns Train Horn for... https://www.amazon.com/dp/B07ZY76DQF?ref=ppx_pop_mob_ap_share
I separated the compressor from the tank and made those quick mounting brackets. The attached to the bed floor on the passenger side at the rear and the tank was mounted below that above the tailpipe. Also custom brackets. It's a tight squeeze for that. The horns i put together in a quad formation instead of flat across and on the driver side above the tailpipe. See post #109 for tank placement.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Completing what the S&B left off the intake system. Waiting on one more part and welding up an aluminum fitting.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260302_172229
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260302_172240
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Relocated the Active Cruise Control radar. Harness required extending. Now the intercooler has completely unblocked airflow. Thank you Ford for making the grille one on the easiest to remove. Couple feet of wiring, wire loom, electrical tape, 8 butt connectors, 1 rivnut, M5 bolt, small spare bracket laying around and 5 zip ties saved me $200 for the ADD part.
EDIT: You will need to recalibrate the CCM system with forscan. I did it 3 times before it finally took. You go to the wrench icon and go to CCM recalibrate. Follow the prompts and you need to drive to over 30 mph till the system is calibrated.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260305_064725
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260305_153852
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260305_162852
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260305_163456
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260305_163705
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260305_164817
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260305_164858
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Picked up all across the board. Didn't spin off the line either. 3/10 with a 3/4 cold air kit. We'll see if the final part of the cold air I'm fabricating helps any.
Ford Ranger RC MUSTANG Azure Gray Raptor Build Screenshot_20260308_075318_dragy
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Throttle body. 60mm to 65mm. Exact port match to the intake. The intake looks pretty good on the inside. Very little oil coating as well. Catch cans working.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260308_104323
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260308_104332
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Intercooler flaps removed.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260308_111636
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260308_111645
Caneman88
Ron
2025 Ranger Raptor MB GLC 300
Pella
Why did you take them off better airflow?
