Stake Pocket Plugs
alrashid2
PA
As of now, my current plan is this:
I have similar plugs to the OP and am going to plug all 12 of the exposed holes below the covers. From there, I'm going to use Duct Seal to seal the edges around each pocket, below the cover. Duct Seal is that dark grey, forever pliable play-do like stuff used to seal foundation holes for electrical, ducts, etc. Similar to rope caulk but designed to last indefinitely without drying out.
Will it be as good as others fixes here? Definitely not. But I don't need waterproof. I just don't want a bucket of water in my bed each rain 😅 My tonneau already leaks so just want to eliminate as much as I can.
Ford Ranger Stake Pocket Plugs 1787319244570-03
alrashid2
PA
Update: tried the stake pocket duct seal and unfortunately it wasn't good enough. Still had some leaks, though it did improve a bit. I'm assuming there is just too much little gaps and flex for it to work correctly.
I just can't believe nobody has made a viable product here. You think it'd be a no brainer. I'd pay 100 bucks for a set of 6!!
I'm thinking of just doing what some others have done and using black silicone caulk to seal the pocket cover in place. Not the prettiest but not sure what else to do here.
Ford Ranger Stake Pocket Plugs PXL_20260910_163705916
WESTRESCUE77
J
Westchester, NY
KEKO came out with replacement stake pocket covers. I installed them a couple weeks ago and they significantly reduced leakage. in my bed. Here's the link: https://kekousa.com/product/util-rev-kit-ved-cacam-ranger-24-us-bord-lat-sup/
FYI - You'll definitely have to clean out the putty in your pockets for the new covers to fit. Highly recommend using a trim tool to install them.
alrashid2
PA
Hey, I was actually the one to find these in the previous post haha. I'm glad they worked for you but they did NOT fit my 2026 pockets. Thinking there is a difference
alrashid2
PA
If anybody with a 24-25 is interested in the Keko waterproof pocket covers, reach out to me first
SoulMafia
2024 Ford Ranger XLT 4x4
Thanks y’all, these worked like a charm!
Loudpa
I was always thinking of using waterproof tape over the pockets. I've use this tape to repair car covers and they stayed fade free, and waterproof outside for over a year.
Here's a mock up not trimmed exactly nor attached since I don't have a tonneau cover yet.
Ford Ranger Stake Pocket Plugs pocket
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
There are a number of problem areas contributing to the leaks. Stake pockets are major but won't make near enough difference alone. The 33 holes in each rail under the rail caps need sealed as well as all the other holes thru the bed, but are less important. The big holes in the front corner are a huge leak while driving, plus water blows in the open front end of the rail caps. One of the biggest leak solvers was running a rope caulk the length of the rail under the rail cap, to prevent any water that does get in from simply running over the edge into the bed. It took all these to seal it up so that in heavy rain or a car wash I rarely see a few drops inside.
There's a number of threads with pics (including mine) that detail the scope of the problem. Good job Ford....
https://www.ranger6g.com/forum/threads/weatherproof-bed-project-diy-writeup.28611/page-2
FergyA
LA County, CA
'24 Ranger XLT FX4
Mech. Engineer
I'd love a set but they've been out of stock since you left your one star review (on a product that only says it's for 2024's... Just sayin). I was traveling and didn't want to order til I got home, but not gonna happen it seems. I contacted Keko and they say they aren't sure they're going to restock them due to being poorly received.
alrashid2
PA
It says 2024+ - id take that to mean 25 and 26 too!
Maybe they're going back to the drawing board?
Loudpa
24 & 25 bed rail caps are the same height, 26 are much lower in height.
FergyA
LA County, CA
'24 Ranger XLT FX4
Mech. Engineer
It's a pretty well known fact that the 24-25 and 26 are different rails.
I don't think they're reengineering them, it's a product from Europe that was successful there that they seem to have decided isn't worth continuing here. (That's hyperbole though, the rep said they haven't decided yet if they will restock them, so there's still a chance). I'd recommend anyone who actually bought one for a 24 or 25 leave a positive review.
The item description says 24. Just sayin.
Ford Ranger Stake Pocket Plugs Screenshot_20260925_112356_Firefox
alrashid2
PA
Yes agreed, so Keko should not list it for 24+. I did let them know their information was incorrect
