The ULTIMATE guide to lifting your Ranger Raptor
scuba mike
Southern Calif
Hvac Job Foreman
Truck looks great.. so just to verify only installed 1.5 in the front ?
Sure! Pic is a little cramped but more flat. Again I wanted to leave a little rake (dont like nose-up, will be adding MOLLE panels, stability, etc.). Happy with it! Rock Krawler kit is perch collar style like GOAT.
mooner3
Michael
California
Thanks man! Yes 1.5" only in front, but I just noticed I totally typoed my post before, Rock Krawler are strut spacers like the GOATs, I think I wasn't paying attention when I wrote that.
scuba mike
Southern Calif
Hvac Job Foreman
Ok thanks.. again love the look of your truck.. time to do mine.
QUOTE="mooner3, post: 421027, member: 13542"]
[/QUOTE]
sikedsyko
24 RRaptor, 05 Z4
Do the ride height sensors need to be calibrated if you replace the entire sensor? My front right is broken at the arm on the sensor itself, not the linkage. Debating how much hassle the warranty would give, the truck is stock and has seem relatively minor offroad use. Sensor itself should be easy enough to replace. If its just a part swap I'll just DIY, but if it needs some calibration I'll probably just let the dealer handle it.
nedmo
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Which part broke?
If going with 285/75R17's (33.8" or +1" diam increase over stock KO3's), do you need a rear lift or is there enough clearance in the rear to just do a 1" front and 0" rear on 34's?
I know the rear has some extra wheel well clearance over the front since the live rear axle doesn't steer like the fronts.
nedmo
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Bang on. The rear does have more clearance at full comp so a 1" front spacer lift is all that is required for that tyre size.
OK now im really tempted once the stock KO3s wear out!
1. Not paying for extra set of tires since replqcment would be necessary anway at that point. Already have to pay for mount and balance too so no extra cost there either.
2. 1" spacers in front only are $205 + cost of alignment if I do install myself (not my first rodeo as they say).
3. Gains a couple of degrees in approach, and breakover. Guessing the departure would be a wash as the slight gain in height would most likely be offset by loss in rake angle yielding a net zero on departure.
4. Maintains functional rake, should still allow for a reasonable payload but im sure youll induce a reverse rake sooner than you would with stock rake since you have less rear squat margin.
[((10.7" + 0.8") / 10.7") - 1] × 100 = + 7.5% increase in min clearance
[((10.7" + 0.5") / 10.7") - 1] × 100 = + 4.7% increase in min clearance
Pretty close in overall function, but FAR fewer drivability tradeoffs compared to 315/70s.
donkey
California
Just do 35x11.50r17 and go full send
aft86
Andres
New York
Lexus LX570, Lexus ISF, and Porsche 991 Turbo S
Has anyone had problems with over extension of the brake lines, breather hoses, and bump stops when doing a lift?
nedmo
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Brake lines - No
No breathers on the Raptor suspension
Bump stops are on the shock shaft. So strut spacers have no effect on bump stop engaging at the same point. We detail this extensively in the post
GOAT spacers are the way to go for lifts. Honestly, I'm not seeing any point in Fox's new shocks for the RR. The RR Race truck never had over heating issues with their factory 2.5 shocks, they only used perch collars to adjust ride height to compensate for the weight, clear the 35x12.5 BFG race tires and "lift the nose" a bit for more clearance in Baja. They added limit straps to stop the harsh top-out with the additional pre-load, other than adjustable perch collars and limit straps, the stock 2.5's have run Baja and Finke 3x now without any heat issues.
Fox's aftermarket shocks for the RR are a bit larger with front Reservoirs and adjustable height and I'm guessing pre-load, so they do offer that for those really wanting to test and tune, but for 99% of those wanting a lift and bigger tires, then strut spacers + ride height cal + tie rods is all you need! That or mod your fenders up front which is what the RR Race truck did.
