What color are your lug nuts
Gray Ranger
James
North Dakota
2025 Ford ranger lariat
I was imagining what it would be like to change a tire at night with black lug nuts.
I stuck with chrome, one piece.
I added a half inch spacer with silver extended lug nuts. What is the torque on the lug nuts? I read 100 ft lbs and I also read 150 ft lbs. What have you heard or read?
Jakeraider
Gene
Simi Valley, California
2024 Ranger XLT Sport 2.3 litre eco boost
Deez nutts are black. Wheel Accessories Part Store. 25.24 for 24 pack on Amazon. Decent quality
scuba mike
Southern Calif
Hvac Job Foreman
any one have pics of black lug nuts on ranger raptor wheels.. part numbers ruff price.. seen some advertise but come on over 125.00 $
Alaska_Wolf
From Eagle River, AK.
USAF Retired
If you read your Ford Owners Manual:
Wheel Nuts
Ford Ranger What color are your lug nuts imagen2
WARNING: When you install a wheel, remove any corrosion, dirt or foreign materials present on the mounting surfaces of the wheel or the surface of the wheel hub, brake drum or brake disc that contacts the wheel. Make sure to secure any fasteners that attach the rotor to the hub so they do not interfere with the mounting surfaces of the wheel. Installing wheels without following these steps can cause the wheel nuts to loosen and the wheel to come off while your vehicle is in motion, resulting in loss of vehicle control, personal injury or death.
Bolt Size lb.ft (Nm)1 M12 x 1.5 100 lb.ft (135 Nm)
1Torque specifications are for nut and bolt threads free of dirt and rust. Use only our recommended replacement wheel nuts and or wheel bolts.
Retighten the wheel nuts to the specified torque within 100 mi (160 km) of driving after the wheels were removed.
150 ft lbs can cause them to to fail and snap off prematurely.
surfstar
CA
2025 Lariat 2.3 FX4
My truck came with lug nuts and in SoCal I don't worry about them seizing, so I'm running OEMs and a thicker wallet.
I tried to match mine as close to paint color.
Ford Ranger What color are your lug nuts Beside Red 3
25Dsand
Sioux falls
2025 ranger raptor
usps
I have stock but would like a bronze to match but don't think I would get a decent match so black will probably be on the list
Geo8866
2025 Ranger Lariat FX4
I just ordered OEM black lug nuts. $900 black appearance package and they give you chrome lug nuts with black rims. I guess they saved $50.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Ford Ranger What color are your lug nuts rraptor_leveled__post_settle_passenger_sid
OE non-beadlock Raptor wheels with black Gorilla nuts
Cyberwiz64
Martin
South Florida
2026 Ford Ranger XL
IT
Thank you for all the feedback. Another issue has come up.
The other day I got a good look at the wheels and was examining the lug holes. I am try to determine what lug nuts these rims need. I have attached a drawing of the lug holes. The primary hole is a straight cylinder. At the bottom is a flat ring and then a smaller cone shaped hole. If you have these wheels, what lug nuts fits it?
Ford Ranger What color are your lug nuts Lug Hol
Ford Ranger What color are your lug nuts Flat lug nut hol
Cyberwiz64
Martin
South Florida
2026 Ford Ranger XL
IT
This kit seems to come up. Are these the lug nuts?
M-1012-BR
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
The inner (bore) hole shouldn't be cone shaped all the way thru the bore to back of wheel, if you were to measure the diameter where the cone starts, the diameter of where cone ends, and the distance between those points, the cone angle could be calculated which is very likely to be 60deg.
