Wheel and Tire Fitment Picture Thread (sticky?)
Sticky thread?
  • Total voters
    88
simonsays
Simon
2022 Ranger
Luckily no, no rubbing, and I didn't have to trim anything either and I have stock suspension...I was prepared to have to get a set of new crash bars or to remove them, but lucked out.
Nice thanks for the answer. Im looking at a 2025 and I would like to transfer my Methods 305 +25 offset on my winter tires, 265/70/17. My summer set up, +20 offset on 285/70/17 would not fit for sure, but if i can put my winter setup until i get a proper lift to fit my summer set, it would be amazing.
Seems that there is more room in the wheel well on the 6g vs the 5g. I had to replace the crash bar on my 2022 Tremor.
NevadaBob
Nevada
2024 Ranger Lariat
Toyo Open Country AT3 285/70R17
Bronco 17" take-offs +55 offset
Truxxx 1.5" level
No trimming required. About 1/2" space between tire and upper control arm
What engine do you have? 2.3 or 2.7? I was under the impression 285's wouldn't fit with +55 offset wheels.
XORegonian
Greenville, SC
I have a 2024 Lariat with a 2.3. They definitely fit with stock offset. 265/70/17 fit easily before the leveling kit as well. These were both toyo open country at3 tires, some other tires may be wider in the sizes mentioned.
NorTexRanger
Richard
2025 Ranger XLT 2.3L FX4
Another look at the control arm clearance. Unscientific approach, but nevertheless the measurement is accurate.
2025 (built 08/2025) XLT FX4, OEM wheels, 255/70-17
I guess I’m just too conservative, so I’m going with the Nokian Outpost nAT 255/75-17.
Different tire makes/models certainly have different dimensions but with a baseline of LESS THAN 1/2” clearance?! How does that accommodate any sidewall bulge? What about running lower tire pressure off-road?
The 255/75-17s will give me about 1” more diameter, so hoping that puts minimal stress on the transmission (and only 2 mph difference on the speedo/odo).
Eibach Stage 2 kit on order, so I’ll post picts after install with the tires.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_3050
Jon_M
Jon
SLC UT
2024 XLT FX4
I’m running 275/70R17 Toyo Open Country AT3 on stock rims with a 1” strut spacer. No rubbing. I bought the truck with the spacer & my plan is to swap out the spacer with a 1-1/2” to 2” lift in the front. I’m waiting to see what other options come out for the Ranger suspension over the next year.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) Truck 1
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) Screenshot 2026-01-26 090023
iBrad81
Brad
Cleveland Oh
I couldn’t find anything that was hub centric that I really liked. I wanted an something similar to an oem replacement. So I had 6061 aluminum forged wheels made that are the hub centric to my liking
These wheels are custom made overseas.
I have a friend who worked with the designer and came back with renderings until it was something I liked.
93.1 center bore
20mm offset
17x9
23lb
Factory size tires 285/70/17
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) 79000-849fa0181275336796a52d4ecd4b0979
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) 79001-7e38de313cfc473ba02fddc86b236125
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) 79002-fca457db1d77f629714977f77eb19140
Wolfman00
matt
crofton md
2024 xlt
that looks perfect! do you have a shot of your spindle clearance? i’m about to order tires, these were not even on my radar
One other metal shell you might consider is from RLD Design, a very similar shell to the Smart Cap and also made in South Africa. I looked at them and while I ended up going with the Smart Cap, many buyers rate them highly.
it appears rld design has gone out of business. i tried their US home page and their Aussie home page and both were no go. all the other searches showing them at other retailers show as discontinued.
just fyi for future people wondering about their stuff
Jon_M
Jon
SLC UT
2024 XLT FX4
Ch&ler
2024 Ford Ranger XLT 4×4
Server
• 2024 XLT Sport 4×4
• Tires: 275/70/R17 Falken Wildpeak A/T4W
• Wheels: RockTrix RT114 17×8.5, +25 offset
• 1.5 inch Truxxx leveling kit
• No mods, cutting, or trimming. The only rub I get is in reverse and full lock but it's very minimal.
Has more poke than I expected, but not in a bad way. Everything looks even better than I anticipated. Just having some balancing issues with the tires but I'm hoping to get that dialed in tomorrow. And the 1.5 inch level leaves just enough rake to be able to load the bed with at least a few hundred pounds and not be nose-up. Very happy with the overall look.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) 20260212_120547
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) 20260212_120455
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) 20260212_172350
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) 20260212_120518
Wolfman00
matt
crofton md
2024 xlt
damn those wheels look good.
My Black RR got the same Bronco SAS rims and Falken 285/70R17 tires my other RRs are running.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5361
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5362
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5359
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5295
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5294
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5291
The OEM Wheels and OEM 285/70R17 BFGs ended up going on one of company Rangers.
‘This Lariat is 100% stock . No lift , no spacers, crash bars still in place.
‘Very very minor rub at full lock in reverse only.
‘Control arm clearance is crazy tight, so tight that you can’t run rim mounted balance weights.
‘But they did fit and have been on the truck a couple weeks now, still doing just fine.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5312
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5316
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5318
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5319
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5317
Very tight fit. Lol
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5308
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5309
Did have to pull the rim mounted wheel weights to get the needed clearance.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_5322
