Wheel and Tire Fitment Picture Thread (sticky?)
Sticky thread?
  • Total voters
    79
Utah
Although quite close to the knuckle, I have not noticed rubbing. The tire dealer did a lot of measuring prior to selecting the 275 cross section size rather than 285 for just the extra clearance provided. Had I installed 285’s, rubbing would have been likely.
robbieb
Squamish, BC
2024 Ford Ranger XLT FX4
Thanks! I have 255 Nitto Terra Grappler G3s ordered but like the look of the 275 size more.
Bronco SAS wheels with Yokahoma 34(295s).
2025 Ranger Raptor.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_4281
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_4290
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_4277
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_4279
SnyperX
Mark
I am looking into a tire swap with fender flares. Would I be able to install fender flares and tires without needing wheel spacers? I don't want the truck looking goofy with not enough tire sticking out if you know what I mean. Thanks.
el_sabio
Randall
Tennessee
24 Ranger XLT FX4
Good idea, struggled to find anything when I was looking:
Raptor
RTR Tech 6 Wheels 0 Offset
General Grabber AT3 285/70 R17
Stock ride height
What are the fenders? I'm strongly considering leaving the stock ride height but bigger tires. I'm getting lots of chips on the back fender from front fender, even with flaps.
el_sabio
Randall
Tennessee
24 Ranger XLT FX4
Raptor
Stock ride height
What's the light bar under the grill?
Stoogey
Stuart
Hampshire, UK
2023 Ranger Raptor 3.0L V6
Fenders com standard with the Raptor? It’s an Altiq light bar 👍🏼
If your swapping tires only and keeping the stock wheels with the stock 50 to 55+ offset then yes adding bulging fender flairs with stock offset wheels will look a little goofy IMO.
Most of the reason for adding flairs is for covering the offset of aftermarket Rims and larger wider tires. A lot wider tire won't likely fit the stock wheel so that is another reason aftermarket wheels typically come into the equation when running larger tires.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) 1758742224191-q1
RangerGobu
2025 Ranger XLT FX4 2.7
2024 Lariat 2.3L 4WD, BFG Ko2 285/70R17 0 offset Fuel Rebel wheels.
2.5 inch super lift with Rough Country fender flares. No rub.
Why did you switch from the Bushwacker Flares you had on before? I was looking into getting the Bushwacker/Ford ones with my Ford points.
