Why is the spare speed limited?
I mean it is a fully specced load and speed rated tire just a different size.
the rim?
Ford Ranger Why is the spare speed limited? FullSizeRender
if the tire is rated for speed, i would go to that speed
It is 112t or 118 mph versus the Tires on the vehicle 111t
so the spare even has a slightly higher load rating
Edit 0.01” difference in diameter, perhaps an issue
i feel like at some point i will get a matching 18“ rim
i make the occasional trip where aaa is not an option
snowman3
us
none
hmm that sticker is surprising. T rating is 118mph. I gotta believe the rim is strong enough to support the weight or normal truck abuse. 255/65/18 vs 255/70/17 is same overall size, or within 1/8" variance I've seen recommended for AWD. head scratcher.
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
.1“ difference in diameter, perhaps an issue
Yeah I would say the difference in diameter would be the reason. Smaller wheel will be turning faster and at speeds it may cause issues with the diff?
1/100 of an inch difference in diameter.
Ford Ranger Why is the spare speed limited? IMG_2366
I took my sticker off the first time I dropped the spare down. On the RR the spare tire is identical to the other four tires, mounted on a steelie.
Peel it off it it worries you.
bigb
Tucson
2025 Ranger 2.7
I didn't know the Ranger shipped with a space saving spare. Will a full size fit under there?
i didn't either but we will fix that, if it is one.
so you are saying we need to drive faster then 73mph on the spare than, ha ha ha
they are the same diameter and width but on a smaller rim
except the raptor where the spare rim is the same diameter
The spare is also a fully rated tire, not a donut
So it is a full size spare, I guess technically
