Will Ford fix the fuel tank size?
rwolfcastle
The worst thing about my Ranger is the fuel tank size. Why did Ford think it was ok to go with a 17 gallon tank when all the competition uses 21 gallons? Does anyone know if they resolved this for the 6th gen Rangers? I think a truck should be able to go over 400 miles on a tank and the current gen Ranger only goes around 330-340.
bill_AUS
Billy
Victoria, Australia
Senior Eng & Tech advisor
Not sure about the US spec vehicles, but the 5G and 6G global Rangers have an 80L tank (which is 21.1 US Gal).
RedlandRanger
Moderator
Rob
Oregon
My owners manual for my 5G shows an 18.8 gallon tank:
Ford Ranger Will Ford fix the fuel tank size? 1675676152364
I'd guess it has something to do with the modified frame for NA, but that is just a guess.
bill_AUS
Billy
Victoria, Australia
The only modifications to the frame are very minor
the1mrb
Duluth, MN
2019 Ford Ranger, XLT FX4
Aerostructures Engineer
If you drive more conservatively you can pretty easily get over 400 miles on a tank. I've gotten over 500 miles on a tank a few times with my 5g Ranger. That wasn't necessarily easy, but it is possible.
But either way, all that said, yes, I do wish the Ranger tank size was larger. Really makes it annoying when towing, especially in places where it's 100-200 miles between gas stations as it is.
DukeCanBuildit
The Interwebs
Ranger
Are you filling up when it reads 1/4 full?
I don’t think the size of the tank is the issue. If you’re only getting that many miles per tank, that’s about 18 mpg or less. I do better than that with a heavy fibreglass topper, 2” level, big heavy tires, loaded up roof rack, fender flares, a bed full of tools, and an air dam delete. I have the aerodynamics of a food truck. A lot of folks on 5g report better than 400 miles/tank and 22-24 mpg.
It’s either your driving habits, cargo, or mods.
AzScorpion
Moderator
Arizona
2023 Ford Ranger Tremor
This has been beat to death on the 5G site. everyone's driving style and commute is different. If you do a lot of city stop n go driving that'll kill it right there. Also hilly areas or being hard on the gas will do it too as you're into the boost. Mine is lifted, larger tires and tuned and consistently it says 420 miles to E when I fill up. The best was 461 when we were traveling so it can be done. But yes I do wish the 6G would get at least a 21 gal tank.
Ford Ranger Will Ford fix the fuel tank size? 1675687878810
RedlandRanger
Moderator
Rob
Oregon
rwolfcastle
rwolfcastle
You're right, I calculated it wrong. I averaged about 21 mpg so I was getting around 360 miles per tank. Still annoying when I know with a 21 gallon take I could have lasted 2 more days to work and back between fill ups.
Equitasforall
Assigned overseas until 2025
2022 Gen 6 Ranger WildTrak
I could tell you, but then I’d have to…
For our diesel versions of the gen 6, Ford actually offers an extended range (36 gallon) fuel tank in the accessory catalog. . Would love to see that as an option back home. The Bronco guys have been looking for one for years, especially on the 2 door…
Ford Ranger Will Ford fix the fuel tank size? 28E10ABE-FDF1-4855-9277-274F7CBA0DAE
OH3Cobra
JP
Indy
Sales
my Shelby GT500 barely gets 200 Miles out of a tank. That could be right foot impacted. But the tank is small. JP
bill_AUS
Billy
Victoria, Australia
Not if you listen for Ford.... :LOL: You'd think it was a whole new design!
Technically it was, it was on the updated T6.2 chassis shared with the Bronco and 6G, just with the 5G body on it and set at the 5G wheelbase.
Apples
Alan
Roswell, NM
2019 Ranger XLT
At least give Ford a job well done; After all, they didn't make the bed bottom as the top part of the fuel tank!
3231haven
Dale
Australia
2022 Next Gen Ranger Wildtrak -RA
Retired Automotive Cad Monkey
The 5G NA ladder frame was a completely new frame as it was down graded from the 5G ROW due to the reduced payload & Towing requirement and a completely different ladder frame manufacturing design. The Bronco ladder frame was completely new and shared very little with the 5G NA ladder frame due to front track location & track width being different and also the engine installation location. When the 6G NA Ranger is released the ladder frames will share a lot of common components in the Front frame area with the Bronco, but again they will be different due to other differences between the 2 vehicles and a 5G Ranger Body will not fit on a 6G frame due to the front track location.
The 6G ranger fuel tank will basically be carryover from the 6G ROW tank as you need the space in front of the fuel tank to meet frontal crash and other possible future programs that they are looking at.
