slobkrieg
Rob
2024 Ranger, High XLT, FX4 ,adv tow
If you are crying about the gas milage in the Raptor , you also need to remember the Raptor 3.0 runs on 91 octane .
Mock01
AZ
2022 Ranger
91 recommended. You could cheap out and run 87 if you wanted. Just with reduced performance. And probably worse gas mileage.
Wayfaring Ranger
STL
if someone buys a performance vehicle and is too cheap to feed it what it deserves...i am judging them harshly.
that goes for basically any turbocharged car, enthusiast or not. but it holds especially true for enthusiasts.
Mock01
AZ
2022 Ranger
Oh, for sure. But they COULD do it. Lol. I miss having 93 and only having 91. No corn either. Boo.
slobkrieg
Rob
I looked at all the motors avaible , and I think the 2.3 would be a good motor . I wanted good mpg
( don,t think gas is going to get cheaper ) . Good towing rate , and dependable motor .
I Thought about waiting for the 2.7 , but worse MPG and 2000.00 add on . The 2.7 in the ranger 4400 lbs truck would would be fast . I wanted something bigger then the Maverick , and smaller then the f 150 .
GypsyDaenger
Jamie
Cleveland
2019 F-150
Electrician
not as high as id like for the normal 2.3. i wonder with my habits if i could squeak a bit more. i average right about 19-20mpg with my 19" 150 with the 2.7.
yoopercharged
That's a really disappointing number for the Raptor. The Braptor is rated at 15/16 on 37s so I'm not sure how we're only doing marginally better with 33's, a smaller cross-sectional area, and a 400 pound weight savings. I was really hoping for 20 highway. This may be the shove I needed to just buy a CPO gen 3 once the 3.5 hits the market.
rwolfcastle
US
Agreed, I was hoping for 20 as well. When I watched videos on the new Raptor from different parts of the world, it sounded like people were ranging from 16 to 20 mpg. If it's really bad, I may only have this thing for 6 months before I sell and start looking at the hybrid Tacoma, assuming that will be any better.
The other problem is the tank size. Ford can't seem to size a tank properly. The goal should be at least 400 miles per tank. The worst thing about my gen 5 Ranger was that it only went between 330 and 360 miles on a tank so I felt like I was always at the pump.
Robo
Audi Q5, VW Atlas
Anyone know what the recommended octane rating will be for the 2.3L?
Wayfaring Ranger
STL
91+
You can run it on regular fuel, but generally despite the higher fuel cost, you'll still end up saving money with increased mpgs when you crunch the numbers.
slobkrieg
Rob
On Fords website they recommend 87 octane for the 2.3 and the 2.7 .
3.0 was 91 octane .
Wayfaring Ranger
STL
3.0 was 91 octane .
The 2024 ranger manual is available and this is a quote from it on page 183:
"For best overall vehicle and engine
performance, premium fuel with an octane
rating of 91 or higher is recommended. The
performance gained by using premium fuel
is most noticeable in hot weather as well
as other conditions, for example when
towing a trailer. "
slobkrieg
Rob
Auto Start/Stop Technology
StandardStandardStandard
Engine Control SystemPCMPCMPCM
Horsepower (SAE net @ rpm)270315405
Torque (lb.-ft. @ rpm)310 lb.-ft.400 lb.-ft.430 lb.-ft.
Compression ratio10.1:110.0:110.5:1
Bore (in.)3.45 in.3.267 in.3.36 in.
Stroke (in.)3.7 in.3.267 in.3.38 in.
Displacement (cu. in.)140 cu in.165 cu. in.180 cu. in.
Fuel deliveryDirect InjectionPort fuel and direct injectionPort fuel and direct injection
Recommended Fuel87 Octane87 Octane91 Octane
2.3 L 2.7 L 3.0 L
Line 10 , last line. Recommended fuels .
Robo
Audi Q5, VW Atlas
So Ford doesn't even know! lol
Wayfaring Ranger
STL
Conflicting info but the website is more likely to not be the source of truth.
The 2.3L has been in a lot of other ford vehicles where they recommend 91+ due to the turbocharger. I'm gonna assume the historical data + 2024 manual references the correct octane. The 2.0L turbo engine also recommends 91+.
If you get the Ford Performance Calibration/Tune, 91+ becomes a requirement instead of a suggestion.
