Extended Warranty
KSQRapter
PA
Maybe someone has some insight. My wife has a Chevy Trailblazer. I was referred to a dealer in the NE and they had no issue selling me a Chevrolet warranty in Florida. How come there is an issue with purchasing a Ford warranty from out of state?
Go to a Chevy Dealer in FL and check if they'll honor the warranty you purchased in the NE. If they do, then the only explanation is they are licensed to do so in FL.
hand-filer
If one LED projector headlight goes out on you, you will be thanking yourself for getting the extended warranty.
Geo8866
2025 Ranger Lariat FX4
I have owned 17 new vehicles in my life. I have never purchased or needed an extended warranty. The way I look at it, I am at least $25,000 ahead of the game if something went wrong. People seem to forget two things: You already have an "extended" powertrain warranty. And people also forget to deduct what they "prepaid" for the extended warranty when they need repairs. No, the extended warranty didn't pay $2,500 to repair (insert repair here.) They paid $500 because you already prepaid two grand. That being said, if you are a person who takes comfort in knowing you have an extended warranty, then by all means get one.
KSQRapter
PA
But, only if you have added the "Interior/Exterior Lighting" package to the Ford Protect warranty, otherwise your screwed.
KSQRapter
PA
I disagree on some of the points you tried to make:
1. You are NOT $25,000 ahead of the game, the game resets with each new vehicle purchase.
2. A manufacturers powertrain warranty ends at 36 months or 36,000 miles, some owners will burn through that in a year or less (especially in states like TX).
3. NO ONE EVER forgets that they paid for an extended warranty, and it's the first thing a dealership checks when doing a repair (they don't ask you, they can see it in your vehicle profile). Warranty repairs are cash cows for dealerships, much easier for them to file a claim with Ford, than have to deal with an angry customer over how much a non-warranty repair is going to cost.
4. Your comment "They paid $500 because you already prepaid two grand" really isn't correct. The highest deductible is $200, not $500. The options are $0, $50, $100, or $200. You can do between 5 and 10 years, and mileage ranges from 60K to 175K.
With all that said, take a moment to consider the sheer volume of complexity in our trucks. None of this is cheap to replace (electronic components are NEVER repaired, they either go back to the manufacturer for inspection/failure review, or their trashed). If your still reading, take a look at the somewhat long list below, all of which are potential failure points.
Beyond the Engine Control Unit (ECU) and Transmission Control Unit (TCU), modern vehicles rely on a highly interconnected network of up to 70 to 100 dedicated Electronic Control Units (ECUs) to manage everything from safety to cabin comfort.
These individual computers communicate in real-time through the vehicle's Central Gateway and localized data networks like the CAN bus. The most critical major control modules are categorized below:
Anti-lock Braking System (ABS) / Brake Control Unit: Prevents individual wheels from locking up during hard braking to maintain steering control.
Electronic Stability Control (ESC): Actively counters skids by selectively applying individual brakes to keep the car on its intended path.
Supplemental Restraint System (SRS): Deploys airbags and tightens seatbelt pretensioners instantly during a detected crash.
Electronic Power Steering (EPS): Uses an electric motor to automatically adjust steering resistance based on vehicle speed.
Body Control Module (BCM): The primary gatekeeper for the car's general electronics, overseeing power windows, door locks, mirrors, and wipers.
Climate Control Unit (CCU / HVAC): Operates the heating, ventilation, and air conditioning systems based on cabin temperature sensors.
Suspension Control Module (SCM): Constantly recalibrates the electronic dampers/shocks at each wheel to optimize ride smoothness
ADAS Domain Controller: The central hub for Advanced Driver Assistance Systems, fusing data from radar, cameras, and LiDAR to control adaptive cruise control and lane-keeping.
Telematics Control Unit (TCU): Handles external communications, including GPS navigation, embedded cellular data, over-the-air software updates, and emergency eCall alerts.
Infotainment Head Unit: Powers the central dashboard screens, radio, smartphone integration, and overall user settings
Off-Road & Suspension Performance Modules
FOX Live Valve Suspension Control Module (SCM): The standout computer unique to the Raptor line. It reads data from body sensors and suspension height indicators 500 times per second to instantly adjust the electronic dampening inside the 2.5-inch FOX internal bypass shocks.
Transfer Case Control Module (TCCM): The "brain" managing the truck's advanced, on-demand 4x4 system. It commands the shift-on-the-fly electric motors to seamlessly transition between 2H, 4H, 4L, and 4A (Automatic 4WD).
Electronic Locking Differential Module: Operates the electric-actuator locking front and rear axles, locking them simultaneously in low-traction environments like Rock Crawl or Baja mode
Active Exhaust Control Module: Controls the electronic valves inside the dual-outlet active exhaust system, giving the driver physical controls to toggle between Quiet, Normal, Sport, and Baja sound modes.
Core Network & Driver Assistance Controls
Serial Data Gateway Module (GWM): The central translator and master gatekeeper for the truck's network. It links the individual high-speed CAN networks together and handles over-the-air (OTA) updates and FordPass connectivity.
Advanced Driver Assistance System (ADAS) Control Module: This co-pilot domain controller fuses data from the 360-degree cameras, parking sensors, blind-spot radars, and forward-facing sensors to drive features like adaptive cruise control, Lane Keeping, and Trail Control.
Anti-Lock Brake Control Module (ABS): On the Raptor, this module does more than stop lockups. It actively changes its slip tolerances based on your chosen Terrain Management System mode, allowing aggressive wheel-slip in deep sand or mud to keep the truck moving.
Driver Input & Cabin Management
Terrain Management / Drive Mode Controller:
Interprets inputs from the physical center console rotary dial. When switched through the seven drive modes, it sends a synchronized broadcast command instructing the ECU, TCU, ABS, and SCM to completely change the truck's personality.
Upfitter Interface Module (UIM): Translates physical commands from the roof-mounted auxiliary toggle switches into fused electrical outputs, allowing you to safely wire aftermarket off-road lighting, winches, or air compressors without tapping directly into sensitive vehicle logic lines
Now, if you are a person who takes comfort in knowing you don't have an extended warranty, then when you have a hefty out of pocket repair, please come back to this thread and tell us how sore your wallet is.
RonEee
Ron
Holland Michigan
2025 Ranger XLT
My friend you are essentially living in the past. I've also had multiple new vehicles over the years and never had an extended warranty but the technology on my new Ranger is concerning. The fact that if an LED tail light burns out I'm on the hook for a $1,200 replacement and that's one of the cheap things to replace. If that sweet 12 in tablet mounted in the middle of my dashboard goes out that's $2,500 according to a dealership rep I talked to. After 3 years that shit can get expensive.
Not like my 2014 f150 I sold last year where I could replace a tail light bulb for $5. I bought the Ford premium Care that extends my warranty out to 7 years which will probably be as long as I will own the truck, if that long. I got it for less than $1,000. With the way quality in vehicle manufacturing has gone down The tubes over the last five or six years, I almost feel it's a necessity.
Geo8866
Life's too short to read this entire post (I'm joking) but I did read the first three.
1. Yes, I in fact saved a total of 25k not buying 17 extended warranties. That doesn't reset; I don't have to give that money back if I need a 5,000 repair on a future vehicle.
2. The powertrain warranty is 5 years 60K, not 3 years 36K.
3. You are correct, people don't actually forget that they paid for an extended warranty, but most people fail to deduct that amount when they post " my extended warranty just saved me three thousand dollars."
I know this is a touchy subject for people, especially for people who swear by them. And everyone has their on comfort level. I can only say that I keep vehicles between 60 and 100K and I have never needed a major repair after my warranty expired. Good maintenance? Luck? Probably a little of both. But I rolled the dice and won.
Geo8866
There's a lot of "ifs" in your post. But what if they don't happen? Again, it is about a person's personal comfort level. People get comfort out of knowing they are covered for every "if." Your example of the $2,500 tablet is perfect. "If" that tablet broke, I would pay $2,500. A person who purchased a 2K extended warranty would pay nothing (assuming no deductible.) I'm rolling the dice. I might possibly pay $500 more. Oh well.
And of course there are the people who will say "what if" multiple things go wrong? Except for the occasional lemon, how often does this happen? The never buying the extended warranty thing has worked for me 100% of the time since I purchased my first new car in 1985.
What do you mean 'already have an 'extended' powertrain warranty'? 5yr/60K isn't extended, especially when you see trans issues 70-90k miles.
Go to the 5G forum. See how many of those wished they had spent $2K when they need their $13K transmission replaced. It can be done cheaper at a trans shop, but many are skeptic about 3rd party shops.
got3fords
James
Central Va.
Love a good do or don't extended warranty debate. I've never gotten one. Will I on my '26 RR? I dunno. It's not like a $4000 repair will break the bank.
Pic-N-Stick
Northern Virginia, USA
Retired Firefighter
But what is the price of a $4,000 repair going to be in 7 or 8 years, let alone a 10 or 12K repair in the future!?
AugPal
Augie
Chicago
Retired IBEW
Interesting discussion
