joordan
Italy
ranger wildtrak 2023
I cant find the TSR can you guide me ?
That I haven’t seen in forescan. It’s coded somewhere else. Do not know how to activate, I have it built in my trim
rugedraw
Javier
Miami, FL
Auto Sales
TSR would need to be enabled here in the APIM (possibly other locations in the APIM in your region:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1787435010100-j9
Enabled here in the IPC (possibly other locations in the IPC, too):
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1787435092528-at
Enabled here in the IPMA (again, may require other TSR related bits to be flipped for it to work):
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1787435204517-r0
Your best option would be to find a Ranger that has it working, pull the ab file from it on the motorcraft site with the VIN, and do a control F on the Ranger spreadsheet searching for TSR in the APIM, IPC and IPMA tabs to see what other bits related to TSR are enabled. However, these three above are the core bits to flip to get TSR to work.
If your Ranger came from a US market, then you would need to change the country code in the IPC and APIM to display UAE road signage. Country code is stored here in the APIM:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1787435516810-yt
And here in the IPC:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1787435538006-1y
You'd need to change 5553 (or whatever is there) to 4145 for the UAE:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1787435611201-eh
Good luck.
tdroesch
Tom
Southern California
2025 RR
Hey All,
Wanted to share my experience thus far with trail turn assist on a 2025 Ranger Raptor.
After following the Forscan instructions to activate this feature, the icon/button showed up on the off-road screen and an on/off slide button was added to the controls page. Unfortunately, when I tried to engage the feature off-road, it did not work. I tried in both 4H & 4L, with the steering wheel full locked, and at speeds under 5 MPH. The controls page slider responds briefly when tapped and appears to slide to "on", but then immediately returns to "off" - and the icon/button on the off-road screen will not respond to touch at all.
However, this may not be the end of the story as I noticed a few new Forscan DTC codes. I made a number of changes using Forscan to my truck that day, but my thought is that these DTC codes may correspond to the issue and provide a clue as to why the trail turn assist function does not work. Here are the codes:
ABS U3001 - Control Module Improper Shutdown Performance
* Additional fault symptom ( :68)
* Status (-68)
PSCM U0415 - Invalid Data Received From Anti-Lock Brake System (ABS) Control Module
* Status (-28)
I also have a third DTC code from the PSCM (Power steering control module), which may or may not be related:
PSCM U023A - Lost Communication With Image Processing Module 'A'
* Status (-28)
None of these have created a malfunction indicator lamp (warning light in dash), but the trail turn control does not work and I am considering just reversing the process on Forscan to see if these DTC codes go away.
If anyone with more skill and/or brains than me can lend some insight as to what my next steps should be, or if anyone else can share their experience with the trail turn assist feature, I would certainly appreciate it. :cool:
Hande
Hannu
Estonia
Business Owner
Spreadsheet instructions do not work in EU RR, I tried many times but could not get numerical displays 🥲
rugedraw
Javier
Miami, FL
Auto Sales
* Status (-68)
* Status (-28)
* Status (-28)
Not sure why it isn't working for you, but these codes are stored codes and not active faults.
alrashid2
PA
Does anyone know how to reset the transmission adaptive learning using forscan? Or is it better to let the dealer do it? I'm at 1200 miles and my transmission is still clunky as ever..
My son said he had to drive his a bunch to get it to feel smooth. 1200 miles isn't enough, maybe 5k?
alrashid2
PA
Oh wow! Then I'll wait a good 6 months. Thanks for the heads up!!
Dr. TJG DVM
TJ
2025 Ranger 4x4 Lariat 2.7L
Veterinarian
Agreed. Mine was pretty rough especially down shifts when first lightly braking. Haven’t noticed it as much lately, just over 6k. But then maybe I’ve done the adaptive learning instead of the transmission and just don’t notice it as much 🤔 😃😃
alrashid2
PA
Time will tell I suppose! Like you said, I think I am also learning how to drive this thing... which is annoying. I've learned to slowly push down the gas pedal instead of hammering it, I've learned to slowly let off the gas in stop and go traffic... just to avoid the cringe of clunks and things in the tranny that feel so wrong lol.
Even still, on my 18 mile commute today had a few clunks: giving it some peppy gas when I got distracted and realized the light turned green had me barely flooring it, but what resulted was a 2 second delay followed by my head slamming back into the seat from the truck finally getting going. Then, in stop and go traffic, I let off the gas pedal only for it to feel like a new stick shift driving popping the clutch rather than slowly releasing the clutch pedal... happened a few times. So clunky. I hate this transmission haha.
midnight270
NNJ
2025 Ranger Raptor CGM
Tried enabling glare free high beams tonight on my 26 Raptor. Tried twice and each time I ended with 4 diagnostic codes, so I rolled back the changes.
DTCs were:
pscm - U023A:00-28 (lost communications with image processing
module A)
RCM - B00DF:4A-08 (passenger restraints disable switch - incorrect component installed)
HCM - U2101: 00-08 (control module configuration incompatible)
IPC - U0415:00-08 (invalid data received from abs control module)
Not sure what the issue is but it feels like something has to have changed?
I did this tonight with my 2025. I followed the instructions on the sheet and got it to work.
Did you follow these exactly?
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1788749412029-f0
Patriot_USMC
Central Oregon
First time user of Forscan. Just attempted to enable the Glare Free/Matrix headlights and couldn’t get it to work. Now I have this error. I used Google Ai for hours troubleshooting, recalibrating ride sensors and headlights. Disconnected the battery for half hour. Headlight calibration fails immediately. Thoughts on how to at least get this error cleared? Tips on how to make the Matrix feature work would be a cool bonus. Thanks a ton for the help! 🙏
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_7977
midnight270
NNJ
Can you post pictures of each module you changed? Maybe you changed a wrong number or letter somewhere .
