Intercooler shutters
B4JA
New England
2026 Ford Ranger Raptor
Hi all - I just received a turbosmart intercooler to address the significant heat soak issues I have observed with the ford procal tune. It seems CRAZY to me that there is a set of shutters that block flow to the intercooler. For the radiator, I get it (to help the car reach operating temperature faster). But for the intercooler it seems like a crazy design on a high performance truck.
what have others done regarding these shutters? I am included to remove or somehow disable them but curious what people have done. Is there a way that they can be held open at all times using forscan?
Crapblaster
Can't be done in Forscan. This is controlled in the PCM. It will take HPtuners setup or get a custom tune from someone like Goosetuned.
OxygenMask
Phil
Eugene, Oregon
I've read here that people have removed them and left the actuator attached. Not sure why...
Might be necessary to have them in winter?
I think they leave the actuator in place and plugged in so no check light pops up. The ecu doesnt know the shutters aren't there because the actuator still moves it's little arm up and down, though no air flow is blocked since the actual shutters are removed
OxygenMask
Phil
Eugene, Oregon
LOL I meant not sure why they would remove the shutters.
I wonder if the shutters are another EPA Formula hack. Active aero. Has no actual effect on anything but their presence gets you an extra .3mpg rating....
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
It does know if you remove the shutters. I cut the end of the shutter that plugs into the actuator and reinstalled it. So, it still thinks the shutters are still there. No codes generated.
Bear376
Stillwater, OK
2013 Mustang, 2019 Mustang, 2025 60th Anniversary Mustang, 2026 Ranger XLT 2.7L
The shutters have a very minor effect on fuel economy. It means little if they are functional or blocked open. The only real option is to replace the intercooler with a high quality replacement. On my 2019 Mustang, I added a CVF unit that was a major improvement on the track.
Crapblaster
They probably have little aero effect on gas mileage. I had a 2017 F150 ecoboost that did not have the shutters. The intercooler would build up condensation and cause the engine to stumble and bog down. Some people drilled small holes in them to help with condensation and some covered part of the intercooler at certain times of the year.
Noob here. Are the shutters for radiator separate from inter cooler shutters? Or is it just on big set?
I don't plan on any modifications, just try to learn about these.
5G Rangers didn't have shutters, AFAIK.
Crapblaster
They are separate(Shutter A and Shutter B) and controlled separately.
TurboRanger
Jack
Oakley , Comifornia
Retired Truck Mechanic
Mine are open all the time . But it is summer It could be a real cold thing and where I live we don't even have ice on the cold mornings. My fans are on all the time. If they wanted it to warm up faster just leave the fans off
JJT
JAVIER
SPAIN
RAPTOR 3.0
If the active grille shutters are removed and the actuator motor is retained using the supplied bracket, no warning message will appear on the instrument cluster. However, a fault code will still be stored and will show up when running diagnostics or scanning the vehicle with FORScan.
This happens because, without the mechanical resistance provided by the shutters, the motor rotates freely and cannot correctly detect its end position.
FORScan cannot fully disable this system. To deactivate it completely, the change would need to be made directly through the ECU. The alternative would be to install a mechanism that limits the actuator’s movement and prevents it from rotating more than 180 degrees.
A specific rotation-limiting kit is available for the Ford F-150, but so far I have not found an equivalent product for the Ranger Raptor.
https://www.tbwperformance.com/add-...85-b735-20fc7b8db2c2&search_query=AC1300900NA
B4JA
New England
Really helpful info everyone. These trucks heat soak like crazy in 75 degree or warmer ambient temps. You basically get one or two good runs before the ECU starts pulling timing. Going to install the turbosmart intercooler this weekend!
