Outside temperature
AugPal
Augie
Chicago
Retired IBEW
I don't think I have ever had a car or truck that had an accurate outside temperature, especially if it's sitting out in the sun..
Hootbro
Delaware
2024 Ranger STX 4X4
I think the ambient air temp sensors are meant to be more accurate under vehicle movement than sitting static and taking reflective radiant heat from being parked on pavement or concrete.
Still though, Ford's seem to be the worse about it.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
Anyone manage to find a fix through Forscan? Mines reading 28°C and it’s -3°C outside!
Noticed your dash is in MPH. So you're using imperial, and not metric. I don't think we can have "hybrid" its metric, or its imperial. 28°F is -2.2°C
Stoogey
Stuart
Hampshire, UK
2023 Ranger Raptor 3.0L V6
I’m in the UK, definitely displays in °C. I just ended up replacing the sensor in the mirror. It’s a shared part with other fords so was only about £18
I can get mine to do both. I have my air pressure on my tires set to psi and other stuff to metric.
ShadowDragon24
2025 Ranger XLT Fx4
So do I. But anything engine related, I can not change, its stuck in metric, as its tied to the "measurement unit" setting in the general settings on the infotainment. Thats why my boost and engine oil pressure are in BAR, but my tire pressure is PSI.
If I change my dash to miles(speedo stays kmph) My boost and engine oil pressure switch to PSI.
Ford Ranger Outside temperature 20260718_153805
Ford Ranger Outside temperature 20260718_153811
Ford Ranger Outside temperature 20260718_153735
Ford Ranger Outside temperature 20260718_153700
Ford Ranger Outside temperature 20260718_153714
I do see however the infotainment has a sepperate temp setting. and when I changed my "measurement unit" to miles and mpg. my ambient temperature and my speedo stayed in metric.
Wallowa Ranger
Eastern Oregon, USA
'24 Ranger XLT Sport 4x4 w/ Adv. Tow & Tech Pkg.
As others have said, this is common across all Ford models. I think it has to do with whatever device measures the ambient temperature. My wife's car (2025 Nissan Rogue) is also usually off by 3-4 degrees, but corrects to within 1-2 degree once you're out driving around. I think its just cars being cars. It's probably hard to get an accurate outside temp reading when the thermostat is within inches of an engine that's 200+ degrees.
80238
My F150 was always pretty close to the actual temperature. The Ranger has been 7-10 degrees high all summer. Driving doesn’t make it become more accurate. Anyone find a fix?
As others have said, this is common across all Ford models. I think it has to do with whatever device measures the ambient temperature. My wife's car (2025 Nissan Rogue) is also usually off by 3-4 degrees, but corrects to within 1-2 degree once you're out driving around. I think it’s just cars being cars. It's probably hard to get an accurate outside temp reading when the thermostat is within inches of an engine that's 200+ degrees.
Stoogey
Stuart
Hampshire, UK
Replace the sensor, got a brand new one off eBay for about ÂŁ18, same as an F250 one as it goes
cb4017
Cliff
Northern NV
2026 XLT 2.7L FX4
One of the first things I noticed after picking up my new XLT was the outside temp read consistently 5-7 degrees high, even after moving for awhile.
