RC MUSTANG Azure Gray Raptor Build
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
Powder coated the leveling spacers code orange. Not that you can see them. 😂 Gained about 1.25-1.5" lift in the front. Calibrating ride height has been made supe easy now. Connect to Forscan, click on wrench icon, scroll down to VDM Ride Height Calibration, hit the Play icon at the bottom, click yes on the prompt, enter fuel level, click OK. Takes about 10 seconds and it's done.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260201_163634
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260201_163637
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260201_172357
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260201_172630
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Enabled Lincoln power mirror fold. This allows the mirrors to fold when you lock and only unfolds when you open the door and sit and/or hit the ignition if the door was already open, instead of opening everytime you open the door. This is done by change mirror fold mode to Lincoln in both the PDM and DDM modules.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
While I was leveling the front I test fitted the 6 piston brake kit and the ROW bracket that originally came with it fit. There is a little spindle clearance required. Just need to verify the braided line is the same. Unfortunately the stock raptor wheels don't give you the minimum needed clearance between the rotor though.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260201_113257
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260201_120850
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260201_123419
Ford Ranger RC MUSTANG Azure Gray Raptor Build Screenshot_20260203_055410_Messenger
daytoncarter
Dayton
Per the Gsheet it says - Note: the tradeoff of using Lincoln Autofold is that puddle lights won't work
Is this true? Are your puddle lights now non-functional?
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
I use silent mode. So, they don't light up. They do light up when it's running and the door is open.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
The Kicker amp ended up pairing nicely with the Skar under seat 10" sub. I'll say that it's probably near as good as the $1000 JL Audio version. You do have to slam the seat bottom a tad to get it to latch. It's got a pretty tall grille. Left the factory sub in and tapped the LOC from the stock sub harness. I did disable the ANC/FAKE ENGINE NOISE with forscan. Not sure if that did the trick or not but I don't really notice any bass drop-off at 18 vol.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260206_151828
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260206_143437
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260130_163520
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Doors don't sound like tin cans anymore.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260208_103619
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260208_104151
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260208_104158
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Added the T harness between the 12v socket for future access accessory. Same one that I pulls pulled from my 2019 and used in the Fusion.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260208_100557
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260208_100540
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Swapped the dash center speaker with an 3.5" Infinity that's been sitting around doing nothing. Highs are a little clearer now. Might do the tweeters later.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260208_121838
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260208_125034
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Forgot I installed this in the morning. Lol. Bass control knob.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260208_190127
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
As done on previous Fords to adjust the accuracy of your Distance To Empty (DTE) you hold the OK button down and then hit the ignition button, whether push button or turning the ignition key on. ET will pop up on the screen. Hit OK till the prompts are gone and you see the engineering screen. Scroll up once and you're at the DTE adjustment. Do the math and divide your actual hand calculated mileage with what's on the DTE. EXAMPLE 18.6÷18.9=0.9841269841 change the number on the DTE screen to 984 and hit enter. That will adjust you to true DTE. This will allow those of you with the big aftermarket tanks to calibrate. Forscan doesn't do this function.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260211_192337
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260211_192444
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
MILspec bed liner on bed and skid plate. Even made the compressor mounted in the bed fender cavity quieter from inside the cab. Sprayed lower bumper fascia with some Herculiner just to kill the bright silver.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260212_135405
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260212_135412
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260212_141711
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260212_151328
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260212_162505
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Molle panels ready but the hold down hook hardware is now going to be a nightmare to remove cause they sprayed over them. 😬
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260212_154100
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Nice job man! I wish I lived near you so we can be buds...and so I can use your lift :)
It's a blessing and a curse. I had to help my buddy swap the fuel pump sender on his trailblazer today.
