RC MUSTANG Azure Gray Raptor Build
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
@AdventureLab Molle panels installed. Mil-Spec were kind enough to remove the tie down hooks for me. Fuel pack and CO2 tank mounts installed.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260213_173614
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260213_173258
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260213_173131
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260213_173141
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Clean side oil catch can. Had to remove the one time use crankcase line and replaced work PCV serviceable fittings.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_112613
Ford Ranger RC MUSTANG Azure Gray Raptor Build 61115b7e-8f7e-44f4-90e3-31f287564237
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_112522
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_145857
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Before and after sound insulation on the roof.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_130639
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_134416
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Tailgate seal.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_181733
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_181746
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_181752
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_181801
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_181831
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260214_181843
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Got dates locked in.
Ford Ranger RC MUSTANG Azure Gray Raptor Build Screenshot_20260218_095619_Chrom
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Added Aux backup light. Perfect fit.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260218_173851
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260218_173913
srv256ss
2025 Ford Ranger Raptor
Some of you have been looking for a solution to the folding rear seat. Well, here it is. You can't fold down the seat back unless you move the front seats forward or remove the rear headrests. Took a set of folding headrests from the previous gen and swapped the covers. I might cut the hole open for the button in the future.
Can you talk me through the swap? I’m at the point you have in the pic, but the foam on the 5g is wider than the 6g.
Did you use the 5g foam with the 6g cover?
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Correct. It's a tight fit but It will fit in there. Cutting a hole for the button is optional. I did install the foam first and then the plastic part button side first.
srv256ss
Thanks!
Getting the buttons on the outside was as easy as using a razor blade around the push button, but inside the bezel ring. Pushed it through. Can’t see the razor blade cuts.
Ford Ranger RC MUSTANG Azure Gray Raptor Build IMG_0220
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Thanks!
I just didn't feel like cutting it at less than a week old yet. Lol
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
14.41 @ 94. Sport mode 4H spinning all 4 tires stock engine with no performance mods.
Ford Ranger RC MUSTANG Azure Gray Raptor Build Screenshot_20260225_143056_dragy
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Air intake system. Puts the stock one to shame.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260225_162330
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260225_162339
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260225_163846
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260225_164234
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260225_170151
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260225_170156
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260225_170203
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260225_170207
jordantii
Jordan
Tampa Bay
www.straptacademy.com
2025 RR
I do like that intake and SB has a great paper filter. My only issue would be water, dirt/sand and mud would hit that filter instantly when off road. Wonder if a baffle could be made to divert the air down and away from the filter like the stock system. But I bet that defeats the benefits of this box. Love following your progress.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
As on my previous truck i run the pre filter when I actually go offroad. It's water repellent and filters to a smaller micro. So, I don't worry about that. Even if it's raining it's hard for water to get up and in there. If you look at the path it would take to get there ford already designed it so things won't go directly into the filter.
jordantii
Jordan
Tampa Bay
2025 RR
From yoiur pictures it looks like a straight shot right to the filter. Nothing like the factory setup. What am I missing? And what is this pre filter?
