RC MUSTANG Azure Gray Raptor Build
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
Why did you take them off better airflow?
Yes, pre mod before intercooler. It says you're supposed to remove them with the intercooler install. BTW, did yours pop a code P05A1 active grille shutter sensor minimum/maximum?
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260308_125820
Caneman88
Ron
2025 Ranger Raptor MB GLC 300
Pella
No code I just snapped tied the grille motor under the bumper to some other wires so far it's good
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
🤔 have you run codes? It's not a code that will trigger the check engine light. I only saw it because i had forscan running to recalibrate the ACC relocation and was looking at all module codes.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Since relocating the ACC radar it could use a little protection. The 4 aside tabs will break off since there's nowhere to latch and it's all flat area. The 2 top tabs latch. 1 of the 3 lower tabs sorted of latches. It's overall a pretty tight fit. So, I have no fears of it falling off.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260311_150146
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260311_150734
waffleso_0
Oakland California
24 Ranger XLT 2.7L V6
Are you sure the ACC will still function as normal when being moved? It looks like the gap it smaller. I assumed you tested everything? Just curious as I would love to do this to my truck but worried i'd screw up the ACC since I use it often..
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
I've performed the recalibration. That's the exact place ADD's relocation bracket puts it for $200. Go look at their bracket.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Little bling.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260312_170216
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260312_170816
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260313_142952
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260313_143016
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260313_143026
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260313_143313
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260313_143554
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Got the final portion of the cold air kit made. I had a brain fart and put the fitting bung on the opposite side. 🥴 On the bright side it doesn't matter as I can just reroute the crankcase hose. Lol. Waiting on paint to dry.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260314_125511
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260314_131550
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260314_161427
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260314_170304
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Draggy run finally done this morning for the throttle body. Throttle body was worth almost a tenth. Might have run a 13.99 in the right condition.
Ford Ranger RC MUSTANG Azure Gray Raptor Build Screenshot_20260321_072154_dragy
spellchek
earth
How did the throttle body help just in terms of "feel?"
Midlifec
Livonia, Michigan
2025 Ranger Raptor.
Throttle body. 60mm to 65mm. Exact port match to the intake. The intake looks pretty good on the inside. Very little oil coating as well. Catch cans working.
Can you share more information on the 65 mm throttle body you used?
Part number? Direct replacement?
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Unfortunately, Maxbore, who I used to get stock ones ported from, has passed away. 65mm Bore plus low profile shaft. Luckily for me this was the same exact one from my 2019 that I saved.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
I believe I mentioned it but I monitor the instant mpg and the throttle input %. It now requires less throttle to maintain the same speed with a higher mpg now. I just did the draggy run this morning and picked up almost another tenth on the quarter mile. So, I say that about a 10 hp+/- gain along with better low speed flow. Hence the higher mpg and less throttle input to maintain the same speeds.
