Removing splash guard for oil changes
Roverhound
Walter
Augusta Springs, VA
Mechanic
Semantics.
We were talking about splash guards. Mine is still not plastic.
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
Semantics.
What is a splash guard?
Do you mean skid plate?
Mudflaps are splash guards....
If you mean the steel protective pan under the engine, in the US that's a skid plate, in AUS its a bash plate....
edited: spell correct kept messing it up...
Bill W
SoCal
2025 XLT Ranger 2.7
If you mean the steel protective pan under the engine, in the US that's a skid plate, in US its a bash plate....
But what about a metal splash guard? Is that for hard water?
josephp732
Joe
NJ & FL
My XL has a plastic splash guard that must be removed every oil change. TBH, it‘a not a big deal. I had a 4Runner once that required to you drop a metal skid to change the filter. Now THAT was a PITA.
Removing the splash guard is nothing compared to Ford’s retarded location for the oil filter itself.
I have 2021 4Runner with TRD Pro skid plate... your not kidding about it a PITA to take off. Always causes me to have noodle arms when reinstalling.
josephp732
Joe
NJ & FL
Thanks all! I guess I should have mentioned I ordered the 2.7 Ecoboost with the plastic pan. Planning on installing the Ronin.
Guess we'll see!
I have a 2025 Lariat with the 2.7l - oil changes are very easy. I installed a Ronin drain plug but then changed it to the UPR drain plug that has a ball valve. I find that you can really control the oil flow very well with the valve handle also it's not two pieces like the Ronin, so you don't have to worry about misplacing the screw in piece.
https://www.uprproducts.com/product...-for-mustang-f150-raptor-edge-explorer-bronco
MK8.5 Golf R
Victor
S.C.
1998 Ford Ranger
All 2.3 come with metal oil pan and valve cover, 2.7 oil pan and drain plug are plastic, not sure about RR. Some trims come with metal guard under engine, mine is plastic. Most difficult task of changing 2.3 oil is replacing the oil filter but once you do it a couple of times you'll get used to it.
Steeliegreen
Oregon City Oregon
Ford F-350 2021 and Ford Ranger 2024 XLT
rETIRED
My splash guards are behind the tires both front and rear!!
Maybe
Brock
CA
23 Bronco, 24 Mustang GT
4x4 XLT BAP with plastic
Bill W
SoCal
2025 XLT Ranger 2.7
The 4x4 off road package 2.7 has metal skid plate with 4 bolts. 2 bolt notches foreword and 2 regular holes rear on plate,
alrashid2
alrashid2
PA
Thanks for sharing! I am not sure which I want to go with as as of now...
The Ronin seems to have superior build quality, but I'm really not a fan of the two piece design. You never know when you may lose the secondary part that must be screwed in. I also am thinking about installing a metal skid plate for the engine area due to the plastic oil pan, which means it may be hard for me to get my hands up in there to be messing with the secondary install/uninstall.
The UPR QT Valve seems much more similar to the Fumoto valves I am used to on my other vehicles, but I noticed that is is much much longer than the Ronin. If I don't go the skid plate route, it would stick out far too far for me to be comfortable with. I also don't like that the UPR QT valve doesn't seem very protected from accidentally opening. At least with the Ronin, it has a few different safeties in case something fails.
I may wait til I get the vehicle and get under it to assess which one I'll go with. Not like I have to buy it in advance, as I won't get my truck until Aug and then I won't change the oil until 5k miles, which at my rate will take me nearly 8 months to drive that...
Ford Ranger Removing splash guard for oil changes 1779820877164-9t
Ford Ranger Removing splash guard for oil changes 1779821018464-65
josephp732
Joe
NJ & FL
I agree, to get comfortable you should get under the truck and look around. Personally, I don't find the plug extends to where I think it would be an issue. Also, the cap that screws on to the end of the plug is billet aluminum with a gasket - I did have the same thought as you, so I opened up the valve and drove around for about an hour and the cap sealed properly - I had no leaks. Note, the valve has good resistance more than the Fumoto valves.
the fumoto won't work for you on this engine, since you already have experience with them?
thats what i have on all the vehicles in the driveway now, fumoto.
MK8.5 Golf R
Victor
S.C.
1998 Ford Ranger
Fumoto valves are high quality, I had the on all of my vehicles, recently switched to valvomax.
