What does everybody keep their tire pressure at?
Robert
2024 Ford Ranger Lariat
I have mine set at 30 psi cold pressure. But the truck seems to drive kind of spongy at 30 psi. Now I’m assuming that you can have a 95% confidence range. So I should be able to go all the way up to 31.5 and actually be in range. Is it all right to run it at 32 maybe.
I run 36psi cold on all 4. Seems to be about right in terms of comfort, traction, and being properly filled for normal use. It's a lot more comfortable than 39 cold, that's for sure.
Btw, I think the school in Utah had us at 28psi (26?) for everything we did. I don't think you'd want to go much lower or you'd risk popping the bead on the stock wheels. Either way, they didn't seem to mind us driving at highway speeds below 30psi, at least for the distances we traveled on pavement.
Robert
That is what I was thinking.
thanks
Ultra45
CA
25 Raptor R
36F/32R on a RR. Probably going to drop the rear more.
Catalyst
Justin
Bend, OR USA
Network Engineer
I also ran 36 cold with OE KO3s. With my 33x12.5R18 Falken R/T01s I’m running 34 cold all 4.
Rangerjimm
2025 Ranger Lariat 2.3
35 cold on the stock wranglers
Alaska Steve
Alaska
32 cold (garage @60°) on Falken Wildpeak A/T4 (stock Lariat wheels) because of temperature drops in winter here in Alaska. Summer temps here are generally in the 50/60s with short periods in the 70s and low 80s. I’ll run the same pressure all year. No need for higher pressure unless you are carrying a heavy load or trailer.
Ford recommends 30 for stock Lariat.
Maybe
Brock
CA
23 Bronco, 24 Mustang GT
I have an XLT with the stock Wranglers. It was way high at 46 from the dealer. I dropped it to 37 and find it better obviously but i know the door jamb says 30 that just seems low. I run my Bronco the same and have been happy with it so went that route here
Texas Ranger
Austin
46 all around simply because The beadlock capable wheels have very deep tire stems so it’s a pita to get air into it.
markal49
Mark
2024 Ranger XLT w/ FX4
Planner
You guys run high pressure. 27 - 28 psi cold for me on an XLT with Kuhmo Road Ventures in stock size. 30 is the recommended pressure. The dealership always puts them up near 40 and it’s an awful ride at that pressure.
Deepsea619
California
Tacoma
US Navy
39/40. 30 seems low.
superbford
Bryan
TX
20 Ranger XLT
Run 36 in the winter, but it is about to start getting really hot here so I'll take it down to 30-31 for summer here in Texas.
