Wheel and Tire Fitment Picture Thread (sticky?)
Sticky thread?
  • Total voters
    89
ryanO
Ryan
2025 RangerXLT
Sales
285/70/17 Toyos Open Country AT3
Method 305 double black 17x8.5 +25 offset
1" lift from Fordrangerlift
Wanted to keep some rake because I will tow a 3700lbs dry weight travel trailer.
My driveway goes downhill, but in that same spot I measured 2.5" of rake stock, and now it's still 2" rake after the lift. Curious that it's says 1" lift but is apparently more like 0.5" lift.
I got rubbing at full lock in reverse and forward on the felt liner, even if i trimmed it a bit prior to the lift. Doesnt seem to run the crash bar so I will just trim a bit more eventually. Nothing too concerning.
Very nice setup!
03GeeTee
Oklahoma
2025 Ranger stx 4x4
Pizza Cutter Time!
255/80/17 Hankook Dynapro XT
Stock suspension
17x7.5 +55 Bronco Big Bend wheels
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_4111
Just put them on today, initial report is that they fit great! No rubbing at all and I've been really trying to test that out to see if I can get them to rub.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_4106
First time running an E rated tire on anything other than an F-350 and they are riding quite smoothly. But I've only driven them in the pasture and a country road up to 45mph so far.
I'll probably do a more in depth report after I get some miles on them. But so far they seem like a very simple and fairly lightweight way to run 33s on a stock truck. I'm at 71.45 lbs per corner (23.25 lb wheel + 48.2 lb tire)
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_4104
Bronze Monkey
Ohio
Pizza Cutter Time!
Stock suspension
How is the speedo? Looking forward to hearing more about fitment without a lift or level.
03GeeTee
Oklahoma
2025 Ranger stx 4x4
I had the speedo dialed in perfectly with Forscan for the 255/75/17 tires I was running previously. However for 2025+ Rangers, you're currently limited to a 2480 max tire size that you can enter in Forscan and I'm already at that limit. So with the new tires being 1" taller than my old 32" tires, I expect the speedo to read around 3% lower than my actual speed. (about 2 mph low at 70mph)
I can live with that, but I'll be patiently waiting for someone to figure out a way to get around the current tire size limit.
Jon_M
Jon
SLC UT
2024 XLT FX4
My driveway goes downhill, but in that same spot I measured 2.5" of rake stock, and now it's still 2" rake after the lift. Curious that it says 1" lift but is apparently more like 0.5" lift.
I got rubbing at full lock in reverse and forward on the felt liner, even if i trimmed it a bit prior to the lift. Doesnt seem to hit the crash bar so I will just trim a bit more eventually. Nothing too concerning.
What mud flaps are you running?
Jon_M
Jon
SLC UT
2024 XLT FX4
Just installed method 703's (+35MM) AND Bfg ko3 285/70/17's. Leveled using bronco Bilstein struts.
Looks good. I’m wanting to bring up the front end on my FX4 & would like to swap out the stock FX4 fronts shocks with 5100’s. Is the front end any softer or any stiffer now? Your truck looks good.
Adamc55
Adam
2025 Ranger xlt 2.7l
My truck is not an fx4 so I'm not sure how it would compare, but I believe I did notice a slight increase in stiffness. Overall I am very happy with the change though and the stance is settling out to be perfect.
Just to add an update for the 285/70/17 tire clearance, I did need to trim some of the front fender liner by the bumper side crash bars and zip tie it closer to the framing behind it. I have zero rubbing now
BigBassDaddy407
2025 Ranger XLT 4x4
17x8.5 , 0 offset, Pro Comp wheels. 285/70R17 Nitto Ridge Grappler.
Stock height?
Bronco Sasquatch take off wheels, 8.5” width, +35 offset. Toyo Open Country AT3 255/80/17 (33.1” tire).
This is what I am going for and I think will become another popular tire size. That offset looks great.
Aftermath865
Clint
Knoxville, TN
2025 Ford Ranger XLT Sport 4x4
Appliance and TV Repair technician for Best Buy’s Geek Squad
2025 Sport 4x4. Stock suspension, no lift or level.
Wheels: Fuel Rebel 18x9 plus 20mm offset.
Tires: 275/65/18 BFG KO3’s.
Driver side tire would grab the front of the liner when at full lock in reverse. Fixed it with a push pin into an existing hole in the crash bar through the liner. No more issues.
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_1540
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_1538
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_1541
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_1550
Ford Ranger Wheel and Tire Fitment Picture Thread (sticky?) IMG_1904
2R4NG3R6
Tony
California
26 Ranger
Put on some Nitto Terra Grapler G3 275/70R18 on the stock BAP wheels with 1.5 spacers and a 2" level. They are a lightweight, quiet tire. The spacers where perfect to go with the fender flares I put on. There's a slight rub at full lock. I need very minor trimming if I can't tie the liners back.
Very nice truck! What fender flares are those?
