- Joined
- Feb 27, 2025
- Threads
- 36
- Messages
- 1,064
- Reaction score
- 1,619
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
- Thread starter
- #1
3 Scientific Experiments to Settle This | Wide vs Narrow Off-Road Tires
I've stated this before, I plan to keep stock tire size even if I ever decided to switch to a different tire type and for good reason. There's also some really interesting info in there on the K03's and just how well they do.
Obviously if you care more about aesthetics, you may use something specifically for a "look", but I don't give a crap about looks it if negatively affects performance. It is also why performance car tires tend to run wider, because it changes the contact patch to a more optimal shape for that application, not the amount of contact area. For lateral grip in corners, you want a wider tire (road course). For drag racing, you want a longer contact patch for forward traction under power.
For off-road, you want grip over uneven surfaces, suggesting a longer more rectangular contact patch, which based on the evidence suggests a narrower tire profile is actually better for outright grip than a very wide tire.
I see F-150's, Silverado's, Ram's and Jeeps all the time with these stupidly wide tires, they have no idea they are significantly reducing their off-road grip...then again most them probably only use their 4WD for rainy days on the highway and for conversation to inflate their ego to 50 psi.
A larger diameter tire may provide more contact patch yet but only with a lower PSI. For sand, I don't think it matters, because it comes down to area and the area is the same with either, just the shape differs. Tire choice and air pressure are going to dominate sand performance.
What's really interesting is how much BETTER the narrower profile response to lower pressure (which is even more advantageous for use in sand). This might really explain why the stock RR on 33" K03's does so well despite "only being a 33in tire" and "just a K03". The combination of tire design, tread compound and shape with the tire's aspect ratio really make the most of it.
I liken this to all the wanna-be racers out there who lower their cars by 1" or more without ever correcting the roll center. Do you know what that does? Increases jacking forces on the suspension and REDUCES lateral grip...they are actually making their car handle worse!
When I lowered the ride height of my 2016 GT by 1.5", I used Steeda's Roll Center corrected lower links to get a proper roll center for the ride height. I tested the car first before correcting the roll center, then after and it was substantial difference at 90 to 100 MPH on large sweepers on the track (typically hold at 90, then accelerate on exit from the corner under power using the throttle to steer, typically hitting 100+ on corner exit into a straightaway).
