2024 Ranger Raptor-Will it need a leveling Kit
Shotz
Charlotte
2019 XLT Ranger (Raptor Inbound)
Home Inspections
So my 2019 Ranger really benefited by a leveling kit (dealer installed). Besides looking better, the ride was noticeably improved. Curious if the Raptor will also have the same nose heavy stance....requiring at minimum a 2" front lift? Looks pretty level in most of the U.S. posts and videos....but hard to tell.
jdlapointe
Maine
Project Manager
I would imagine not, given the raptors tuned suspension with a watts link rear.
goalieThreeOne
Memphis
2022 F-150 Raptor
Nearly every truck has a dive in the front when unloaded.
Will it need it? No otherwise the factory wouldn’t have done it that way.
But if you don’t like the stance, yes you could.
yoopercharged
Nose sits lower as is common with pickup trucks. The suspension is optimized to run at factory height but I'm sure the aftermarket will offer perch collars for those that want to lift the front and level it out.
Ford Ranger 2024 Ranger Raptor-Will it need a leveling Kit 2024-ford-ranger-raptor-exterior-103-645a65e34167c
goalieThreeOne
Memphis
2022 F-150 Raptor
Nose sits slightly lower as is common with pickup trucks. The suspension is optimized to run at factory height but I'm sure the aftermarket will offer perch collars for those that prefer it level.
Perch collar is a bad idea on the LiveValve shocks. It changes the ride zone of the vehicle. You’d need to get it revalved for it to function like it was intended. A shock tower spacer is probably a better choice. Upper control arm replacement if the total lift is above 2.5-3”.
rwolfcastle
This is the same color I ordered and the pictures aren't the best I've seen. That being said, the top two pictures make it look like it rakes a bit in the front, but the rest of the pictures look a bit more level so I can't really tell. I'm sure there's a rake but I also don't want to mess with the factory geo for the suspension.
yoopercharged
All sorts of Gen 2/3 guys run a perch collar without a revalve. It's a totally legitimate option if you can tolerate the minor change in ride comfort. I personally know a few that beat on their trucks very hard and have never had an issue with stock valving. I certainly wouldn't say its a bad idea but I'll let OP make that call.
goalieThreeOne
Memphis
2022 F-150 Raptor
I’d say it’s a bad idea simply because you’re taking what might be the best suspension in a factory truck and making it worse at its job. A tower spacer is just as easy to install. To each their own though. The adjustable suspension is one of the killer features for me so I won’t do anything that will make it worse.
Shotz
Shotz
Charlotte
Home Inspections
Thanks all for the input.
jrRaptor
Maize, KS
What if we lower front and back and just get rid of the wheel gap altogether?
Slyder
Washington
KTM 1290R, '24 Ranger Raptor
Machinist
I'll just drop this little bit of information from the Bronco side of stuff as it could (and probably will) apply to the RRaptor and other G6 Rangers.
The non-Sasquatch Badlands Bronco is essentially 3/4's of a Sasquatched Badlands. There are people with the non-Sasquatch version who've bought a 1" lift/level kit and only installed the lower spacer (the one that bolts between the bottom of the shock and A-arm). It roughly gives you .500 lift to the front.
It's mostly done to assure clearance for when they add 35's with +25/+18/+0 offset wheels (I'm pretty sure +30 offset works also). There have also been other people who've done this to other Bronco versions to reduce the sometimes excessive rake from the factory.
As far as I've heard and read, it doesn't affect suspension ride and such and you 'should not' need an alignment after doing it. But personally, I'd have the alignment checked after doing it, especially if you plan on adding aftermarket wheels with different offset.
The alignment isn't always spot on and has a tolerance zone to fall into when the vehicle is assembled. I've experienced this first hand with a new vehicle and had to have it re-aligned (once the factory specs were released for it).
Doing this won't eliminate all the rake, but it'll improve the stance and allow for some rear end drop with a load. It's just something to ponder while we wait for the trucks and to see if the lift/level kits from the Bronco transfer over. (I'd be surprised if they didn't, since I'd wager some suspension parts are the same on both.)
Ranger#5?
GumbyDammit
are you buying this truck strictly for looks- or do you plan to actually use it like ... a truck? Carrying loads in the bed, towing, etc.? The rear end suspension is higher so it can safely perform the truck duties according to specs. This prevents too much squat and possible driving problems when towing or bed loads at rated capacity.
If you are buying it because it looks cool to you and others that will see you driving it around, you *could* choose to level it with a kit but may have negative consequences in actual uses. IMO a better alternative is simply add some weight in the bed to lower rear height a bit but can be relieved when needed. Possible options are spare tire mount racks carrying big tires you might need off-roading, swing away toolboxes tucked in the sides behind wheel wells, or just unassuming ballast of your own design. Simple 80-100lbs cement bags carried aft could do the trick- but probably not an elegant solution. :crazy:
Mikknj
Mikk
New Jersey
2024 Ranger XLT Cactus Grey
Hi all, I find this a very odd thread. If the Ranger NEEDED a leveling kit Ford should have leveled the truck from the factory. All of the geometries for the front and rear suspension were all calculated and designed for the current rake. That said I think the Raptor might LOOK better level but functionally when you are cresting an up hill and your hood is facing the sky - a couple of additional degrees of over the hood visibility is a good functional design. If you haul anything the truck should have a little range in the rear height to allow for loading and settling down the rear end. So, I never level a truck personally because I prefer function over form. The topic made me chuckle so I thought I might start some controversy here and get people to share thoughts on leveling. ( in a nice way )
goalieThreeOne
Memphis
2022 F-150 Raptor
I agree with your first part.
The second part though shouldn’t be an issue for the Raptor since we have forward facing cameras that can be activated with the off road button to see over crests. The leveling kit could be handy for installing larger tires but otherwise, it’s just for looks. Besides, it’ll look just fine with something in the bed adding weight which is What we should be using our trucks for anyway.
Mikknj
Mikk
New Jersey
Oh that's right. I never thought about the tires. That's a very good functional reason. If you can stuff bigger tires under the fender.
