2025 2.3L engine oil filter access
Its just Orielly Auto Parts house brand but they are solid filters and it was for the 24 Ecoboost Mustang
so microguard and they appear to be the same size as the fl-2127
2 15/16”
Maybe
Brock
CA
23 Bronco, 24 Mustang GT
Oh it is microguard lol. My bad been saying it wrong the whole time haha. Maybe they are i honestly haven’t seen a 2127 i just paid attention to the thread pitch. I just asked the guy at the counter for a 24 Ecoboost filter and they didn’t have the 2127 in stock but had the microguard and i knew immediately the threads were bigger than what was on the filter i bought that was a 910 equivalent from Fram.
Meatbag
Illinois
2025 Ranger XLT 2.3 4x4
my 2025 2.3 is going to be just over 900 miles and going to change oil later this week. to me just by looking, it looks most accessible by getting a small foot stool and leaning over by reaching your hand/arm down and breaking it lose there. may as well take it off that way too. i may go underneath and check it out from the bottom to see if it looks any better but we'll see. going to be running the Mobil 1 M1-102A filter with Pennzoil Ultra Plat.
also, still seeing conflicting info on the oil capacity. the online manual shows 6qts and the pdf version is showing 5.6qts. both show "including the oil filter" as well. glad they could make this clear as mud lol.
mtremmel
Wi
2024 ranger
Just did my first oil change on 2.3 2024 ranger. Hopefully next time will go smoother. Turned the wheel all the way left and removed wheel liner . Used a long extension on a cup type filter wrench. Discovered you don't have to remove the front skid plate, just loosen the 2 back screws and remove the second skid plate. Thought I followed the drain path for the filter but was off by over a foot so I got a nice oil puddle on my garage floor. Hopefully I learned something and number 2 will be quicker and cleaner.
you can reach the 24 model 2.3 filter from underneath if you reach between the sway bar and cross member. my first oil change, i did from the top, like you are raying @mtremmel , and the one i just did, i did from underneath. both ways work fine but i need a small step ladder to reach in from the top so its easier to just drive up on the ramps and do the stuff from the bottom.
yes, just remove the second aero shield from the bottom to access the drain plug
Meatbag
Illinois
Update for me. I just changed oil for the first time in mine. I was looking underneath and I can def get my hand on it from there but I don't have the greatest leverage, at least to break the super tight factory filter off. I got a small foot stool and leaned over the fender and I could reach down with both hands and break the factory filter loose. I also took it out that way. Cleaned out the little oil canal thing with some shop towels. Found out the Mobil 1 M1-102A DOES NOT FIT even though their site says it does. Smaller thread. I had to go to my local parts store and get the factory Motorcraft FL2127 and that one fit just fine.
I ended up leaving off that plastic shield underneath as well that goes under the oil pan. I feel like it's totally not needed and it'll save time for next time. Went pretty smooth otherwise and I'll be much quicker next time.
MK8.5 Golf R
MK8.5 Golf R
Victor
S.C.
1998 Ford Ranger
From underneath the vehicle it's not too difficult to remove with an oil filter removal tool. Oil filters will tighten up after they're installed and using a removal tool makes it much easier. The 3/4" threads filters are no longer compatible with the new 2.3 ecoboost, 22MM threads are required now, most websites are still showing the wrong filter because they haven't updated their system, I've contacted Wix, Purolator, Fram and a few others, they were not aware of the changes but are now working on getting their systems updated. Other new models equipped with the 2.3L show the correct updated part number. In my opinion, this is happening due to the lack of information about this new engine.
Maybe
Brock
CA
yea i posted a thread on the filter issue and its been discussed in a few other threads that the manual and some companies hadn’t updated as the engine change wasn’t known. Ford now just updated their online manual from what ive seen. The threads are now M22-1.5. I asked for an 24Ecoboost Mustang filter when the fram filter i bought didn’t work.
Corvette, '24 Ranger
Agree with the FL2127 and 6 Qt of 5w-30 oil for the '25 2.3L engine, as I just finished the first oil change.
DO NOT TRUST most online auto parts places as they are still referencing the old engine filter. I know, as my Purolator Boss PBL10241 doesn't come close to fitting, yet that's what AAP shows as the correct filter.
I took the factory filter down to local Ford dealer and we verified 2127 is a cross reference match to factory black filter, the 2025 Ranger parts guide, and also to the 2024 Mustang 2.3L filter. Worked like a charm.
Also, I found the filter easiest access from the top, leaning over fender. There is a plastic drain guide under the filter to catch oil as you unscrew it so make sure your drain pan is set correctly. Note: do what is easiest for you.
I just finished the first oil change and about 5..5 quarts came out so im going with the 5.6 thats in the manual as the correct amount
https://www.ranger6g.com/forum/threads/2025-2-3l-fx4-oil-change.20682/
look at this picture below in poured the oil back into the container on the left.
the middle container is new in opened and the one on the right has the extra 0.5 qts missing
i figure it is easy to add 1/2 a quart if I am wrong
also while I think you can come up from the bottom from the rear, don’t see how you can go straight up from the bottom
i too got out a step stool and came from the top and that was very easy.
now that the filter is white it will be a lot easier to see and change.
and the factory fomoco filter is the same size as motorcraft fl-2127 so you can use the same filter wrench
Ford Ranger 2025 2.3L engine oil filter access IMG_0118
Ford Ranger 2025 2.3L engine oil filter access IMG_0111
MK8.5 Golf R
MK8.5 Golf R
Victor
S.C.
1998 Ford Ranger
Engine Oil+Filter change done yesterday @ 1K miles, 5.7 qts, Penzoil ultra platinum, full synthetic, confirmed 22MM oil filter threads, removed from underneath as planned, easy removal with tool and by hand once is loose. Installed Fumoto drain valve. Planning for 5K miles interval going forward. 4 uncles funnel is awesome, comes with all automotive brand adapters. Hood struts is a must upgrade. Also noticed that the valve cover is not plastic, should last longer.
Ford Ranger 2025 2.3L engine oil filter access 20250702_152907
Ford Ranger 2025 2.3L engine oil filter access 20250702_145646
Ford Ranger 2025 2.3L engine oil filter access 20250702_135200
Meatbag
Illinois
Not that it matters too much but the pdf version of the 2025 model at least shows 5.6 qts. But the html online version shows 6 qts. I'm probably a little overfilled so I think I'll back it down to 5.6 for the next one. Gotta love the clarity lol
Ford Ranger 2025 2.3L engine oil filter access Screenshot_20250704_165341_Chrom
MK8.5 Golf R
MK8.5 Golf R
Victor
S.C.
1998 Ford Ranger
I had it in the garage, made sure it was leveled, poured 5 qts and ran the engine for a few minutes, let it sit overnight, took my time adding tye next day and it took the .7 without being overfilled, as a matter of fact was below by smidget from the full mark. I think that it also depends on how long to wait for it to drain completely, I kept closing the valve and every time I opened it again, oil will come out. I checked various sites and they all call for 5.7 qts, as long as the level is within the range of the cross marks on the dipstick, it's all good and safe to operate.
Just put 6. You wont have all these bottles with oil just sitting around and it won't hurt your engine.
