3.0 eco boost engine intake valves and direct injection!
AlpineBike
Banned
Banned
Andrew
Waitsfield, VT
If the factory crank case ventilation system is working properly and you are using the correct oil, changing it at the proper intervals, and using high quality gasoline. A catch can is absolutely not necessary!!!
This has been proven over and over again on the DI only 2.3 engine and on the 3.0 in the Explorer ST.
eyelise
NorthEast
2015 Ram1500 Reg Cab 5.7L/8spd
I believe the study used an eco boost 2.3L with DI only and did show the benefit of detergents. Maybe the detergents are getting there via the EGR system or possibly there is valve overlap and the intake valves are not completely shut when the fuel is injected. Just hypothetically thinking here
Kit2523
Kit
Phuket,Thailand
2023 Ford Ranger Raptor V6 Ecoboost
Ford uses variable cam timing (called Ti-VCT) to help reduce NOx, so EGR system is not needed. Without EGR, valve deposits can be reduced, but yet still will be present.
BLIZZARDIBLO
Portugal
X6
So no one has 100 per cent sure if the 3.0 v6 ecoboost is direct injection only or dual injection?
No one has photos from engine, or diagram?
No one checked the engine to see?
Hootbro
Delaware
2024 Ranger STX 4X4
No one as photos from engine, or diagram?
Wiring diagrams I previously posted on suggest it is direct injection only.
Aemonn
BLIZZARDIBLO
Portugal
X6
It is direct injection only. How do I know? I went out to my garage and looked under the hood.
10 years from now we're still going to be talking about this.
Can you have some detailed photos?
TheRealSasquatch
Bronco
There are some photos floating around on here taken with a bore scope so everyone can count the injectors. Also anyone that goes to the Raptor assault course can poke there head around the back of the exposed engine on display and see there is no port injection.
Ford needs to fix their typo!
Hootbro
Delaware
2024 Ranger STX 4X4
BLIZZARDIBLO
Portugal
X6
It's a typo that has kited around the internet. Been proven out to be a typo by both service data and direct owners inspection.
I would like to see photos because this is a downgrade ford made from the 2.7 engine and the 3.5.
I had the idea that the 3.0 exoboost would be a reliable work horse. . And missing Port injection, probably Will make it a low reliability engine.
Are there know cases of carbon built up?
Hootbro
Delaware
2024 Ranger STX 4X4
Someone else can do the heavy lifting on that.
BLIZZARDIBLO
Portugal
X6
Iam a bit speechless having in consideration this engine is in production since 2016 and there is not an exploded diagram of the engine, and other information based on technical information. .also engine revisions etc 😱
