A tow that shouldn’t have been
pezdyspensr
New England
2024 Ranger STX
So the trailer (2783lbs) plus 2017 Escape awd (3868lbs) is a total loaded weight of 6651lbs. That's well within the 7500 max but it's not nothing. Very similar setup to the tests that TFL Truck did with the Ranger in their tow testing. No wind frontage either, which explains the decent mpg.
Blue Ridge Raptor
North Georgia
It’s looks like the tow vehicle is a “regular Ranger”, correct? If so, thats well within the towing range for it.
i wonder how a Ranger Raptor would with its measly 5000lb towing limit?
bigb
Tucson
2025 Ranger 2.7
You guys are correct. I stopped and looked at the sticker on the trailer. 2700 lbs
On that trailer the GVWR is 14,000 meaning the total weight of the trailer and load cannot exceed 14,000 lbs. The GAWR (gross axle weight rating) is 7,000 lbs per axle and there are 2 axles. So that is a pretty decent car hauler.
Morningpride
Philadelphia
2024 Ranger LT STX
It’s looks like the tow vehicle is a “regular Ranger”, correct? If so, that's well within the towing range for it.
i wonder how a Ranger Raptor would with its measly 5000 lb towing limit?
Yep, a standard STX/XL with an aftermarket brake controller. This actually stopped better than my camper does behind the Ranger. It was definitely sagging in the rear. I would assume that the leaf springs give the regular ranger its higher towing capacity. The Raptor has coils, correct?
Morningpride
Philadelphia
2024 Ranger LT STX
I would love to know what the tongue weight was. She was sagging a little heavy in the rear.
got3fords
James
Central Va.
Yes, the Raptor has coils.
moproblems
SW MI
I've towed plenty right at an estimated weight of between 4900 to 5300. Does 75 all day just fine. Will struggle without bags with tounge over 10% though.
Sparkherd
Sparky
South Central Texas
Well, when we arrived and loaded the car, I noticed that the weight of said trailer was close to 7000lbs. 🤦‍♂️
Trailer weighs maybe 2500 lbs.
No weigh (hyuk!) 7000 lbs.
My '85 F-250 weighs 7000 lbs.
Cabose-1
Eli
South Texas
2024 xlt 4x2, advance tow elocker
Student
You can tow like this all day long. Good set of trailer brakes. You were well within your limits. I do a lot of towing and here is my setup.
Road active suspension
GEN-Y GLYDER HITCH
And i always use 91 or higher octane.
The road active helps a lot with squat.
The GEN-Y HITCH, Game Changer!!! You will never tow smoother. Lets the trailer and the ranger stay seperated not moving each other around.
91 or 92? Octane recommended by the owners manual for towing. This ranger is a keeper so worth it for me.
Heaviest tow is the pathfinder. 2k trailer and a 4800lb pathfinder. Even the kubota was only 6k total weight. I use a make shift scale on the ranger too. I get a lot of s$&@ for it, but it makes for a really good on the spot scale.
Tow safe, and
Keep the rubber side down.
Ford Ranger A tow that shouldn’t have been 20260207_190929
Ford Ranger A tow that shouldn’t have been 20260419_094648
