Break in oil change before 9 hour trip? Currently at 1500 miles
beaudointl
Ontario, Canada
2007 F150, 2011 Mustang, 2021 Bronco Sport
Technician
2026 Ranger XLT FX4 currently 1500 miles. Planning a 9 hour trip, highway and mountain roads. Should I change the oil before the trip. New to the site, thanks all.
Yes, It is a good time for your first oil change anyway.
boraxman
Santa Clarita, Ca. USA
Well what did you end up doin OP?
crawford
craw
Ontario, Canada
2020 Ford Ranger
i would change the oil after the trip.
i bought a new ranger last august. i went in to have a recall done and added an oil change on my recall appointment. i had about 1200kms on it at the time. the service advisor talked me out of doing the oil change saying it isn't necessary. i mean usually people say they convince you to pay for things that aren't necessary so if he was actively trying to stop me from spending money there the reason must be good? was good enough for me anyway!
oh and there is no such thing as a special break in oil these days.
AugPal
Augie
Chicago
Retired IBEW
Be careful with Service Advisors not all of them are on top of everything. When I bought my Ranger in for the Side Curtain Airbag recall, the Service Advisor called me and said, "You didn't tell me the whole ceiling needs to be removed, you'll have to leave it overnight" . A Service Advisor should be on top of recalls.
natethegreat42
Nate
Minnesota
Ford Taurus
Just to add my 2 cents - I changed mine first at 1850 miles. So, given how long your trip is, I would probably have the oil changed. Now, I also do my oil changes every 3000 miles.
Buckster
2025 Ranger Raptor, 2008 F150
I like to get the wear metals out of the system early. Changed mine at 500 and 1,500 miles. I fully geeked out and sent oil samples to a lab. Silicone went from 90ppm to 40ppm. Total Metals went from 41ppm to 20ppm. With the early oil changes done my regular schedule will be every 5k miles.
NM Mike
I didn’t change my oil early. I did it at 5000, 10000 and 15000. Other than the cost of the oil change, there’s no downside to doing a break in oil change. If it gives you peace of mind, then go for it.
Bill W
SoCal
2025 XLT Ranger 2.7
There is no wrong answer. I do like listening to Lake Speed jr. cause his business is used oil analysis. About the only thing he said I do not agree with him is to pre fill an oil filter. Personally, I do the "flood mode" after an oil change. That eliminates any manufacturing boogers in the new oil.
I did mine at 1,800 miles too only because I wanted to drive more when it had 1,500 on it before taking the time to change the oil lol. Give or take a few hundred isn't going to matter, the primary reason for an early first oil change is to get silicone contamination out of the oil from mfg. process and the high wear metals from break-in.
The Ranger service manual only gives a 1,000 mile break-in period, so I wouldn't personally change it before the break-in is finished, but after that, I would say change it. BTW, Ford MC 5W-30 FS is now GF-7A spec, so any new batches of oil coming from MC has some added benefits over what came in my truck (weather it's blend or full synthetic) since my is a Nov. 24' build, right before they released the updated GF-7A formulation to replace the outgoing GF-6 spec.
I get my MC FS from Rock Auto, it's way cheaper there. I have no idea why MC FS is so expensive everywhere else. My only caution is, make sure whatever you use meets Fords spec for the oil pump wet belt compatibility as that will be affected the most long-term.
I've used a variety of oils in the past from Penzoil Ultra Platinum to Valvoline's FS etc, my UOA's weren't really any different between any of the top brands, in fact MC seemed to not so ironically come back just as good or better in some cases, so I concluded the obvious, Ford's own oils should always be a safe bet and changing oil suppliers isn't really worth the time / testing unless you just like doing oil changes and UOA's for fun...I saw a similar trend on the Mustang 6g forums back when I had my 2016 GT, MC usually did better than most of the "boutique oils", not always, but more often than not and that makes sense, Ford blends their oil additives to tailor them to their engines!
BTW, this is the ONLY info in the service manual regarding breakin, but I recommend following it very stricly in the first 1k, otherwise you'll end up with rings that don't seat properly and a engine that uses more oil its entire life = less performance.
Oil dilutes fuel octane and contributes to carbon buildup, so people who "run it hard" from day 1 are actually making their engines run poorer! The PCM will pull timing more frequently due to oil contamination causing additional knock. And we all know for TGDI engines, carbon buildup can become an issue over time under certain driving conditions and lack of maintenance, that would only compound the problem of buildup on the valves and piston heads, further reducing air flow, trapping more heat etc.
Driving Hints - Breaking-In
Ford Ranger Break in oil change before 9 hour trip? Currently at 1500 miles 1785442064055-i
surfstar
CA
2025 Lariat 2.3 FX4
^ correct reference - the owners's manual.
Nothing about changing the oil early though. Do it to make yourself feel good, but don't pretend it makes any difference for engine longevity and/or performance.
Seriously.
How many millions of vehicles are out there? How many owner's perform the minimum or less maintenance? How many have oil-related failures? Minuscule.
Chippewa76
Midwest
Ford Car, Truck, & SUV
Whether an oil lists GF-6 or GF-7 means they are certed to that spec. That does not mean that the oil formulation has necessarily changed.
btw, for those that depend solely on oil analysis numbers … do those numbers consider the build up of contaminants and wear inside the engine?
AugPal
Augie
Chicago
Retired IBEW
Seriously.
I guess you didn't watch the video
