HenryMac's Build Thread: 2019 Ranger XL STX FX4 Magnetic Super Cab
Lmood
Adam
Savannah, Ga
2019 Ranger XLT FX4
Ford Logo'd Otter Box Cooler
When we bought our Ranger in mid September 2019 they had a special going where you got a free cooler. It arrived today. It's an "Otter Box", Model Ventur 45.
Wow.. really nice quality and made in the USA. And the "Ford" branding is pretty cool too.
Man thats nice. Hate that Ford didn't do anything like this when I bought mine.
Johnpenn
Rockwood TN
2019 Ranger Lariat FX4, 2004 Corvette, 2005 Ranger Edge
Retired Quality and EHS Manager
No worries! Thanks for your input. I'll change my data above.
And interestingly enough the Mobil 1 site shows that the Mobil 1 Annual Protection Ultimate Full Synthetic SAE 5W-30 Motor Oil is superior to all their other oils for our turbocharged Ranger motors.
https://mobiloil.com/en/product-comparison?p1={750237b0-a15c-4fd5-bdaa-24d61c3519e7}&p2={6f399141-eac1-4ba1-940a-f409f3e10238}&p3={91d544a1-74d6-4033-9266-5e863373453e}&p4={13d37eac-ed45-4e21-ba36-944912a51197}
I was originally planning to switch to the Ford full syn. Did you fid the noack number for that in your research?
HenryMac
HenryMac
Central Colorado
2019 Ranger SuperCab XL - STX - FX4 - Magnetic
Craig
Craig
SLC
2019 Ranger Lariat
CSA
WeatherTech Floor Liner Installation
I installed a set of WeatherTech Floor liners today. What a great product.
Here's a comparison from member Northlight comparing the WeatherTech's and Ford's optional liners. The Ford liners are just a piss poor design. There isn't even any tray under the gas pedal, so all the "gunk" on your foot ends up going on the floor, not into the liner? And there "safety warnings" molded into the drivers side mat is lame too.
love weather Tech ave tan seats like tan floor mats, they don't make them in that color for the Ranger
HenryMac
HenryMac
Central Colorado
Agreed... I'd have preferred tan myself. The black shows dirt like crazy.
HenryMac
HenryMac
Central Colorado
Door Sill Scuff Plates, continued from Post 42
Modified the sill plates by using an air die grinder and cut off wheel to remove the rear mounting tabs.
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 001.JPG
_________________________________________________________________________
Then used a 4-1/2" angle grinder with a 60 grit flap disc to level out the remaining stubs of the mounting tabs.
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 002.JPG
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 003.JPG
Next step was using a palm sander and 80 grit.
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 004.JPG
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 005.JPG
When I test fit the sill plates they were a bit to wide and hung out over the edge of the sill. I used the angle grinder and 60 grit flap disc to remove the top lip and sanded it down flush with the top rib.
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 006.JPG
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 007.JPG
And here they are mocked up, ready for tape.. or silicone.. or ????.
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 008.JPG
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 009.JPG
The tape I bought to mount these isn't going to work. It doesn't stick to the plastic sill plates. Here's what I tried to use. Anybody have any suggestions on what type of tape would work best in this application? How about clear silicone?
Link to Installation Using Silicone
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 010.JPG
Lmood
Adam
Savannah, Ga
2019 Ranger XLT FX4
Did you try cleaning the trim with some isopropyl alcohol? It's possible you released some oils in the plastic when you were sanding. I've never not known that stuff to not stick to something.
HenryMac
HenryMac
Central Colorado
I did use some Acetone after sanding the surfaces... but no, I didn't use any isopropyl alcohol.
Lmood
Adam
Savannah, Ga
2019 Ranger XLT FX4
Hmmm. 3m makes an adhesion promoter, but you may have to go to an auto body supply shop to get it. They could probably also recommend a different 3m tape.
Cape Cruiser
Bret
Southern Delaware
1931 Ford - 2017 Tacoma-19 Ranger 4x2 lariat
retired mechanic
I think that tape likes a smooth surface. Small dabs of clear silicone should work. Nice job!
HenryMac
HenryMac
Central Colorado
Door Sill Scuff Plates, continued from Post 52
Ended up using some GE 100% clear silicone to attach the scuff plates to the door sill plates. Used blue painters tape to hold them in place... and some duct tap on the end just to make sure they didn't lift up while curing.
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab 000.JPG
HenryMac
HenryMac
Central Colorado
Drawing of the Door Sill Scuff Plates...
Just in case anybody want's to modify some of these for other applications.... here's a couple drawings and a pdf.
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab Ranger Sill Plate Rev 1 Sheet 1 of 2
Ford Ranger HenryMac's Build Thread: 2019 Ranger XL  STX  FX4 Magnetic Super Cab Ranger Sill Plate Rev 1 Sheet 2 of 2
HenryMac
HenryMac
Central Colorado
When your truck says it is out of fuel.... how much fuel is really left?
(Somebody asked this ^^^ question in another thread. I answered it there, and thought I'd post it up here for future reference)
When we picked up our brand spanking shiny new 2019 Ranger SuperCab at the dealership the "Miles To E " display showed "0 " miles of fuel remaining, and the out of fuel chime was ringing.
We drove about 3 blocks and filled up the tank with 91 Octane Top Tier gasoline.
It took 18.524 gallons before it shut off the pump. Fuel capacity per page 319 of the owners manual is 18.8 gallons.
18.8 - 18.524 = 0.276 gallons remaining.
Reactions: Doc
HenryMac
HenryMac
Central Colorado
Pickup Box Bed Tie Down Hooks and Bolts
Continued from: Where are my missing bed tie down hooks
Got a call from my local Ford Dealer today. The back ordered Bed Hooks and Bolts were ready for pickup.
They wrote it up as a Service Warranty Claim so there was no charge.
Here are the part numbers in case you need them:
Tie Down Hook - Ford (KB3Z-21550A74-A) $6.49 ea, Quan. (2) = $12.98
Tie Down Hook Bolt - Ford (-W505594-S450B) $3.90 ea, Quan. (4) = $15.60
__________________________________________________Total = $ 28.58
I need to buy a tap to chase the threads in the truck since the truck has the ford factory sprayed Toughbed liner in it.
