- Joined
- Feb 27, 2025
- Threads
- 29
- Messages
- 830
- Reaction score
- 1,196
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
- Thread starter
- #151
When I started in performance cars, my first was 2015 Mustang Ecoboost. I did the Livernois 93 tune and cracked a plug insulator due to detonation. Almost trashed the engine, when it happened, I thought I had destroyed a piston since I heard a loud single ping one day just out of the blue when giving it some throttle on a back road. Then a flashing check engine light and very rough idle, I limped home and started to diagnose, thinking I had just destroyed the engine in my first performance vehicle!
Pulled the plugs to get a borescope in and look for damage and found one of the insulators cracked and slid down on the plug electrode but got hung up on the end so it didn't fall into the cylinder. Got lucky. Their tunes are NOT the safest. Some people don't have issues, but I really do not believe they are anywhere near as reliable as FP.
I ended up selling the Livernois programmer / tune and then bought and FP Power Pack, NEVER hand any issues with it, never any pinging, no cracked plugs, no drivability issues etc. Also, with the Livernois 93 tune I was getting pinging sometimes when running the same octane as the tune (so 91 on 91 tune), so I had to revert to their 91 tune and then run 93 octane. The cracked insulator happened before I had downgraded to their 91 tune on 93 octane.
Was it aggressive and fun? Sure, but not worth trashing an engine for! The only mods that car had were the tune, an intercooler and FP cat back exhaust. So, it SHOULD have been fine...clearly it wasn't up to snuff and maybe my car had more production variability than they accounted for.
On a built bottom end, I think it would have been fine running 91 tune on 93 octane. On a stock bottom end? Disaster waiting to happen. I will never use theirs or anyone else's ECU cal's on a stock Ford engine again.
My opinion:
1. Aftermarket ECU Cal's should ONLY be used for engines with built bottom ends (i.e., a custom race / performance street engine with forged Mahle rods and pistons).
2. On stock blocks, Ford Performance or factory ECU cal's only. Period.
I cannot tell you HOW MANY Mustang Ecoboost's and even GT's ended up with trashed engines using non-Ford ECU cal's on the Mustang forums, it was a shockingly frequent occurrence.
Maybe if your running E85, you can get away with aggressive big power non-Ford ECU cal's on a stock bottom end, since E85 really helps with knock resistance due to the cooling effects, but then you're at blending fuels and most often modifying injectors and fuel pumps etc. That's well beyond factory hardware and a huge PITA for most people.
Plus, the RR is an off-road truck, 99% of actual off-road terrain doesn't even allow you to use the full power of even a stock RR...let a lone a Pro cal tuned one, because of suspension limitations. You'll out-drive the chassis before you'll run out of power, so it's really only on the street where the extra power matters and for me, the Pro Cal adds enough to hit that "Raptor-like" sweet spot.
My opinion:
