SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸
Garaged
Usa
Ranger raptor 2024
Gents
Just received seemingly SL 'v2' of DRL conversion kit; coupla observations:
  1. Boards now include three (3) pre-drilled, alignment holes to match heatsink base
  2. No thermal paste included...?
Before embarking on install...is thermal paste recommended or required?
> If so, can someone please provide a spec for purchase [since not an electrical/electronic guy :wink: ]​
I think you should reach out and get them to send you thermal paste. I just got my v2 package a couple days ago with the extra holes and it does have a tiny tube of thermal paste in it.
smokinjoe64
SoCal
BMW M3 (e92); Ranger Raptor
Appreciate your comment...just discovered the syringe filled with paste at bottom of pkg envelope.
I was expecting a tube similar to previous posted pics.
Corrected my original post. 🙌
lifeline
Chicago
Just did my install. It was a pain in the ass but would be nearly impossible without the flexible driver. I used a jack to raise each side so I could get my head in the fender well area and removed the fender bolts to pry the fender back while my helper started the top two T15 screws on each sides. Make sure you take a look at the connecter and how it attaches before you try releasing it, it comes apart very easily if you depress the tab with your finger nail, it needs very little force. The kit I received was revised so nothing had to be cut off. I'm impressed with the kit, the look is very OEM and how it should have come from the factory.
iBrad81
Brad
Cleveland Oh
Still waiting patiently on mine, its made about 15 or more stops
Icemilkteaa
Northern California
96 m3 00 m5 15 335i 6sp 06lr3
I just did the install, and want to add some thoughts and tricks I discovered.
I decided that I would pull the wheel, and the entire fender liner. This would give me a straight shot in.
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 IMG_6467
I also found that removing the horn helps a ton. The bracket nut didn’t want to come off. But the horn itself has a nut behind it.
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 IMG_6468
edit: I pulled fender bolts on drivers side, but found that it made no difference in the way I tackled the install, so I did not bother removing on passenger side and it was a breeze after above steps were taken
smokinjoe64
SoCal
@Icemilkteaa appreciate these tips/approach.
Just received my kit this week.
Did jus a prelim only look & feel... there's no way my hand will fit tight space to maneuver top-side, even with flex-extension and fender loosing.
> My concern, not just getting screws out, but confidently able to access/reinstall without losing screws and bits in engine bay 'black hole'.​
A few questions:
  • Clarify - Assumes suggesting both sides wheel removal for install?
  • Access Related - Remove both side screws and reinstall from only 'bottom up access' or combo top/bottom?
  • Any 'different' tools used/suggested beyond those previously noted by others?
  • Clarify - Why horn/assy removal?
Welcome comments/suggestions from All...
0ak9
GA
A few questions:
all these tips are great, but I think my biggest help was having an extra hand - especially one whose hands are smaller than yours 😂
with two people, I was able to get the entire process completed under two hours. both of our hands were scratched to hell upon completion, but honestly it took a lot of angling with the flexible tool and a whole lot of “hold your finger here” to keep the screws from falling and getting in the right hole.
I wish there were more tips, but it just takes severe patience and a lot of cursing. +3 for beer 🍺
one more thing: the white clip that comes off the led chip has two small grooves on them that require you to depress in order to get them out easily. If you go brute force option, you will likely pull the each individual female connector running into the headlight out without the clip… highly do not recommend, because it becomes a guessing game on which wire goes where. **if you go a few pages back, one of our members posted the correct wiring sequence for reference**
Icemilkteaa
Northern California
A few questions:
I have normal sized hands and did it solo, but I probably have a higher than normal pain tolerance for annoying things.
Both wheels removed yes. This allowed me to sit inside the wheel well, so that I could see all three screws from the bottom. Each wheel well has two liners, and I removed both. By the time the big one is out, the small one is 2 t15 and maybe 4 push clips from coming out so you may as well pull it.
The screw that you can see from the top, I did use the flexible ratcheting screwdriver to access from the top. With the wheel liners removed, I was able to have one hand underneath the guide the tip (that’s what she said)
The other two screws were both accessed from the bottom. I have a really nice small Hazet driver set that was great for reaching these. I would recommend for most people to have some quarter inch drive t15 and a few extensions. I think with the horns removed, these wouldn’t even be an issue.
horn removal was so that you can use normal sized tools to reach the two screws accessed from the bottom. You’ll find your wrench hitting the horn, and that you’re essentially bending around. You could probably make do with the bendy screwdriver, but why not undo 1 single 10mm nut
My concern also was not being able to get the screw back in… this turned out to be pretty easy once you figure out removal.
JrHDRanger
Indiana
Mine is arriving today and I have a week off work that just happens to coincide. I’ll definitely be rereading all these posts beforehand. Thanks for paving the way guys.
lifeline
Chicago
I was considering removing the horn as well but made it work by just unplugging the horn connecter. Removing the horn would have made it easier.
NASSTY
ME
I thought about removing the horn as well. But with the felxible tool it wasn't too hard to just work around it.
Peter
Milwaukee
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 IMG_8096
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 IMG_8099
Got mine today finally and went to town on it. Recommended tool should also be a friend with skinny arms and small hands. I could not for the life of me plug the connector back in but I called up a buddy who was able to magically fit both arms in a plug it back in. Whole install took me like 6 hours. Not sure if others recommended it but taking out the horns also gives you a bit more space. Definitely love the more aggressive look
Fawnbuster
Indiana
Is It possible or easier to install these with the grill removed on a RR? I was going to paint my FORD letters to match the truck and install a lightbar and amber grill lights at the same time.
NASSTY
ME
I don't think it would help or give you better access to the DRL modules.
Maybe I'm wrong? It was about 8 or 9 months ago when I removed my grill to install lights and I just did the amber DRL swap 2 weeks ago. So my memory is a little foggy on what it looked like with the grill removed.
Fawnbuster
Indiana
Thank you
