SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸
  • Thread starter Deleted member 9086
  • Start date
  • Watchers 50
lifeline
Chicago
grille removal wont help, the module is on the fender side of the headlight.
Garaged
Usa
Ranger raptor 2024
Painful but the fender move helped. Only one side done so far and my board is still copper but the extra hole was mis-drilled and just misaligned enough ....and I'm a little disappointed that I had to break the OEM alignment pin.
The other side didn't have that problem, the holes accommodated the guide pins, but were a little 'too' big. So, even with the screw turned all the way in, you could still slide the board around a bit.
Either way, it works, and I like the look. Pardon the dirty PPF on the headlights - haven't really cleaned since Moab lol.
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 20250607_194840(0)
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 20250607_201720
Fawnbuster
Indiana
For anyone else who dropped and lost one of the three T15 screws holding the module in place, I can confirm these are the correct part to replace them lol..
Wise words from a man with experience...? ??
NASSTY
ME
I thought I would end up losing one or more. I dropped one but it fell right down through onto the garage floor.
However, I dropped one of my T15 bits after I already had the fender liner all buttoned back up and the wheel back on so I said oh well that one is gone. I found it in the driveway a week later. ?
Fawnbuster
Indiana
Was it right next to the missing
10mm socket?
ATXian
ATX USA
'25 XLT V6
Recommended tool should also be a friend with skinny arms and small hands. I could not for the life of me plug the connector back in but I called up a buddy who was able to magically fit both arms in a plug it back in.
Just imagining how that phone call went:
Hey, you know how you've got those bird bones? Anyway so I got this headlight thing…
JrHDRanger
Indiana
Figured I’d start working on installing the lights this evening. Took me about 5 hrs. I have the updated version, holes all lined up perfect. Only issue I had was the top screw, that was probably over 2 hrs itself combined for both sides. They look great, especially with the M&R light bar on.
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 IMG_9906
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 IMG_9907
JrHDRanger
Indiana
Congrats @JrHDRanger...
What was your top screws challenge?
Remove tires?
The top screw on the module was slow to remove. On the drivers side I was able to just get the tip of my thumb in and finish unscrewing it when it was halfway out, so that was a big win after doing passenger side first. I pulled the tires and the horns, but there isn’t much space to work with. Glad it’s done. I saved the original modules, but I don’t plan on having to do that again.
iBrad81
Brad
Cleveland Oh
Reading everyone struggling with this, I just pulled the headlights out, was it quite a bit of work yea, but not to bad.
worst part is having to remove the fenders
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 IMG_8215
Ford Ranger SIGNATURE LUX Lava" Amber DRL Conversion Headlights🇺🇸 IMG_8216
JrHDRanger
Indiana
How long did that take to remove per side from the start?
