Tonneau that doesn't leak?
Rangerjimm
2025 Ranger Lariat 2.3
I have the tonneau from the thread linked below. There's pictures of mine in that thread, if you zoom in you can see the black silicone between the trim and bed. The gorilla tape isn't visible, it's way up near the bulkhead covering the large openings on the left and right. Some people say they've shoved a tennis ball in the openings to prevent water and dust from coming in.
https://www.ranger6g.com/forum/threads/willmoso-retractable-tonneau-cover.14282/
Ok thanks again. So with doing this you didnt have to plug the other smaller holes inside the bed? I have read others have filled those holes with rubber grommets.
D. Sampson
Dana
Albuquerque, New Mexico
2024 Ranger Raptor - Shelter Green Metallic
Hey there - I didn't do anything beyond what I described, no grommets. If the stake bed caps and the sides are sealed, nothing is going to leak down to the holes. If the holes are filled with grommets, but the stake bed caps are leaking above them, water is still going to get in. The problem with only filling the holes is the inside of the plastic bed trim is not sealed on the inside of the truck bed. In my opinion the stake bed caps must be sealed. Here's a picture with the arrow showing the inside gap that will leak if only the holes are filled/covered but the stake bed caps are not sealed.
Ford Ranger Tonneau that doesn't leak? IMG_1529
Trimjb
Tennessee
2024 Ranger FX4
That's lot of holes under the caps.
I'm sure they all must have a purpose.
Rangerjimm
This is why the Rangers bed gets wet. It’s best to take the plastic covers off and seal all the holes with vinyl.
How did you get the 2 front plastic prongs closest to the bulkhead?
ZBOBMAN
Robert
CINCINNATI
Mustang GT Ranger Raptor
Sorry for being late to the conversation. Have owned 4 pickups in the past and am buying a ranger raptor. I have always installed an Undercover bed cover and have never had a leak problem. Does undercover make a cover for the ranger raptor?
MichBadger
SE Michigan
2024 Ranger Rapto
I’m the OP for this thread. I ordered a Diamondback cover over the weekend. I also have a roll of sign vinyl, a pack of rubber grommets, and some silicone caulk ready to go before I install the Diamondback.
I know this is overkill for a lot of people, but I want the bed area waterproof.
gtyates
Greg
Goodlettsville
2019 Ranger Lariat 4x4, 2021 Explorer Limited 4x4
Manager
I have the Bakflip MX4 on mine. So far I have added a tailgate seal kit, used grommets to fill many of the holes around the sides of the bed, but for the life of me I could not figure out how to fill those useless holes at the front corners of the bed, right behind the cab. The attempted solution I am trying is flexseal tape in white to match my truck. Time will tell if it makes a difference. I ran it through a carwash yesterday without the tape installed and it looked like those corners are about the only place I got water in the bed.
SubNuke
Richard
Houston
How did it go? I just ordered me a Diamondback and am now waiting on its delivery.
MAV
Arkansas
Here’s what I’m doing to keep mine from leaking:
Ford Ranger Tonneau that doesn't leak? IMG_3149
Ford Ranger Tonneau that doesn't leak? IMG_3148
Still testing the design, but it fits very snug and should eliminate most of the water seepage through the loose fitting stock caps. If not, a very thin layer of silicone should do the trick.
Not shown here, but they have threaded studs on the bottom that accept 1/4” thumbscrews to hold them in place.
Breakthrough
Ontario, Canada
2025 Ford Ranger XLT
Did you 3D print those? I'm curious if a rubber seal of the correct length would fit as a seal (either for those custom closer fitting ones or the stock one).
I've been using silicone for mine but it doesn't seem to adhere well to the plastic. So far it's been water right but isn't the most aesthetic solution, and I suspect will need to be redone periodically.
Was wondering if anyone found a more reusable solution (repurposing some kind of rubber gasket), or if folks have had luck with alternatives like FlexSeal.
MAV
Arkansas
Yes, designed on Sketchup and 3D printed. I've installed a test set, but I haven't had a chance to put water on it and check for leaks. With the factory caps, lots of water leaks by the loose fit - enough to get the bed and cargo pretty wet in heavy downpours.
My thought is that if more than a couple of drops get through these new caps, a very light film of silicone around the perimeter should seal it completely. I would rather not use silicone at all, but with the tight tolerance fit, just a thin film should suffice and not be visible without close inspection.
