Water leaks from bed rail caps.
Ag3ntC00p3r
Product Manager
I installed my Retrax last night. This is what I did for the stake pockets.
I removed the stake pocket covers.
Put some rubber grommets in the holes.
Put a bead of silicone on the rails that are under the covers.
Put the stake pocket covers back on.
Ran a bead of silicone around all four edges of the stake pockets.
Installed Retrax.
I have a tailgate seal kit coming next week. Hopefully all that will reduce water/dust intrusion as much as possible.
Here are pics right after a long pressure wash after the pockets were sealed and Retrax installed. Pretty good in my opinion. I just got the tailgate seal kit and will be installing it sometime this week to see if it gets better for both water and dust.
Ford Ranger Water leaks from bed rail caps. IMG_0629
Ford Ranger Water leaks from bed rail caps. IMG_0630
Silent Thunder
Lorenzo
Houston
2018 TRD 4Runner, 2023 Challenger WB Shaker, 2024 RR in Shelter Green
Had some time today. Took off the bed caps. It’s like friggin Swiss cheese under there. I cleaned up and dropped a layer of Orcal 651 (whatever color I wanted to get rid of). Popped holes in the vinyl for the caps to go back on. Later siliconed those penetrations from below. Then you can put your taillights back.
We she’ll see.
What did you end up sealing the front of the bed (gap) with and how are the leaks after your mods?
Jeffola
Southwest Florida
Business Development
Gap was closed by a foam seal included with my tonno, honestly, its still leaks, I need to get under and seal up the penetrations from the caps with silicon.
iamweasel
Down Yonder
Ford & Cadillac
For those who used silicone/caulk in the cracks of those bed caps, how is that holing up?
Cabose-1
Eli
South Texas
2024 xlt 4x2, advance tow elocker
Student
They sell bed rail caps that do not have the giant square holes on them. However, they are sold overseas. So i have no idea about exchange rates or shipping to the usa
Moonlit
Pittsburgh PA
2025 Ranger Lariat (Marsh Gray, Rear Locker and BAP)
Mine have been doing good - Dry in the bed area. Just chasing leak up in the front of the bed in the corners (where my Tonneu cover meets the bed)
Reactions: GLW
Grand Nat
NYC-Long Island
Schwinn Sting Ray
I have a Lomax tonneau cover that works great but it doesn't fully cover the bed rails. I noticed leaks from the bed rail caps and the only fix I could think of was to seal around the caps with clear silicon. I think this would be the same with any tonneau cover that doesn't fully cover the bed rail caps.
Anyone else had this issue?
This will cure that leak. LOL
Ford Ranger Water leaks from bed rail caps. Ranger roller cover
Rangerjimm
2025 Ranger Lariat 2.3
I didnt like the way the silicone looked so I bought some 1" closed cell foam and cut it slightly larger and thicker than the stake pocket holes. Then put the caps back on. Seems to be working well. I also put black vinyl patches over the holes inside the bed.
Ford Ranger Water leaks from bed rail caps. 20250528_195109
cforput77
Craig
2024 Ford Ranger XLT 4WD
That was the main reason I got a cover that sits on the rails. Cover doesn't leak it all the holes in the bed. Thank's Ford. :facepalm:
What cover did you buy? And now that a few months have passed, are you still dry and happy with the cover?
It's a Bison and yes still dry. I don't get any water from the stake pockets. The only water I get is around the tailgate. I have had it on there pretty well since I bought my truck so around 15 months.
BigOleOgre
Nate
STL MO
Field Service Engineer
We she’ll see.
Thank you for this. Took my bed rail covers off today (only broke 4 clips, same 2 on each side broke perfectly flush, will be jb welding them back) and doing exactly what you described today. Vinyl the rails, pop rail covers back in, and silicon from below. Like really who tf at Ford approved this Swiss cheese design-with bed rail caps that have built-in water pass through? Blows my mind and concerns me.
Ford Ranger Water leaks from bed rail caps. 20250830_135528
Ford Ranger Water leaks from bed rail caps. 20250830_135543
The robots have to pick it up somehow. No holes then they would have to weld something someplace and you don't want that. :p
