Engine oil pressure?
That's exactly what mine idles at 21.8 PSI.
IIRC, varying the oil pressure is also how they control the cam phasers.
Bubz58
2025 Lariat 4x4
Glad I caught this thread! I just noticed yesterday the same guage movement as the original post and was a bit panicked about my new 2025 2.3l until I got to the end - lots of great info from the Ranger community. Thanks everyone!
ryanO
Ryan
2025 RangerXLT
Sales
I can display oil pressure, trans temp, and boost on my XLT, through the off-road menu - vehicle gauges.
Your oil pressure is variable and controlled by ECU. It's how it varies cam timing thru the cam phasers.
To be clear, you have to be in off-road mode to display them, correct?
I have an FX4 XLT and would love to be able to display them outside of that mode.
IIRC, it's in the Off Road menu, but you can select it to be in MY View, so that whenever you select My View, it will display that screen.
ryanO
Ryan
2025 RangerXLT
Sales
So I think I misunderstood or misread your statement earlier. Yes, I have those bar graphs in "my view" but I want actual numbers, not just the graphs.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
from the factory service manual. for the 2.3 for oil pressure
Ford Ranger Engine oil pressure? Screenshot_20260410_141018_Adobe Acrobat
Ford Ranger Engine oil pressure? Screenshot_20260410_141027_Adobe Acrobat
I think the numbered display for oil and temp is a Raptor exclusive.
ShadowDragon24
2025 Ranger XLT Fx4
Makes sense. Hence why I'm looking at getting an OBDII Port Bluetooth device
OBD Link MX+ with their app is Android auto compatible. when you open the app on the radio, it automatically makes your phone connect. you can only display 4 pods at a time while driving, when parked its 7 or 8? but you can set up multiple screens for 4 at a time. Volts included. the mx+ gets you all the enhanced diagnostics updates for free, vs the mx, where theybare like 20 bucks each. but you can watch the oil pressure on the off road screen too. with truck set in metric, it displays in bar tho. with is set to imperial you do get psi.
Ford Ranger Engine oil pressure? 20250809_104255
Ford Ranger Engine oil pressure? 20260309_190059
ryanO
Ryan
2025 RangerXLT
Sales
Hold up! I can display trans temp, oil temp, coolant temp and something else on the screen while I'm driving!?
ShadowDragon24
2025 Ranger XLT Fx4
boost, trans temp, and oil pressure in the off road menu on the instrument cluster. yes. then in the cluster settings you can add the rpm to the left, and oil temp to the right.
so you can have in left to right coolant temp, rpm, speed, boost, engine oil pressure, trans temp, engine oil temp, gas. thats without using any obd scanners.
Ford Ranger Engine oil pressure? 20251201_191453
I have an OBDLink MX+ but didn't know it is AA compatible. Can it display gauges? Or just data as shown?
ShadowDragon24
2025 Ranger XLT Fx4
You get 4 pids while in motion like this. but you can see my above theres like 7 or 8 on the one page you can look at while stopped in park, or neutral. a few weeks ago I found I can set up sepperate pages and scroll through them while driving.
You have to be disconnected from AA altogether and you can set your pids you want shown on the obd link app on your phone.
Ford Ranger Engine oil pressure? 20260413_135036
Ford Ranger Engine oil pressure? 20260413_135039
Ford Ranger Engine oil pressure? 20260413_135042
Ford Ranger Engine oil pressure? 20260413_135253
Ford Ranger Engine oil pressure? Screenshot_20260413_135441
Ford Ranger Engine oil pressure? Screenshot_20260413_135449
DanielRayJ
Daniel
Highlands, Texas
2025 FORD RANGER RAPTOR
Have a new 2025 Ranger Raptor with 1000 miles. The oil pressure gauge indicates around 25% if low was zero and H was 100% When driving at 2200 rpm it runs in the low 30's. When near full pedal it runs 55%.
For sure it never goes into L but wondered are others seeing similar readings.
Still on break-in in oil and level is full.
Does anyone do the flooded start method to build oil pressure prior to starting. Basically hit the on/start button without touching the brake pedal. This will bring up the gauges and let you see the oil pressure. Next put your foot on the brake pedal and hold the gas pedal all the way down. This will allow the engine and oil pump to prime the oil galleries. The starter turns the engine about 300 RPM. 2-3 seconds and the oil pressure gauge shows 21.8PSI. Let your foot off of the gas pedal and the engine starts. I really don’t think the fuel injectors open until you let off of the gas pedal. I hope it doesn’t. Anyway can someone comment please.
