2025 Ranger - Bed 12 Volt Outlet - Final Update
DrIanMalcolm
Anthony
Thanks for the discovery and guidance on this one. I ordered the OEM replacement part for my ‘25 and it should be here Friday. I’ll report back, install looks to be straight forward.
DrIanMalcolm
Anthony
For me, the hardest part was realizing that I could access the connector from under the truck. Thanks again @PMK - this is easy, cheap, and very useful.
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update IMG_5741
They Call Me Bruce
They
Uranus
2026 Ranger Lariat
Retired Sparky #164
So just for clarity, the wires are already there , this is just a remove and replace, plug and play item, correct?
Thanks for the quick reply.
If you have the bed ac outlet, then yes, this has been a plug and play update for the 25
I don’t know if anyone has done a 26 yet. To verify that 12 volts is still wired to the connector underneath.
you could snap a picture and verify 6 wires are running to it.
it Is the red and green on this connector that carry’s the 12 v so hopefully your plug underneath has corresponding wiring.
it should have purple and black as shown.
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update IMG_0121
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update IMG_0122
DrIanMalcolm
Anthony
@They Call Me Bruce correct for my 2025 RR. The OEM 2024 panel is prewired from a connector. I simply removed the existing panel (4 screws), followed the wired into the inside of the bed rail, removed two support clips (there are two replacements already on the new part), and pulled the connector apart from underneath the truck next to the exhaust. Followed the same steps in reverse to install the new one.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
I can confirm the 2026 harness works as well. I didn’t use the OE 2024 panel, but added my own pins to the panel-side harness
They Call Me Bruce
They
Uranus
2026 Ranger Lariat
Retired Sparky #164
Thank you for that.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
A pic of my 2026 appears to show black and purple wires.
So should be good to go or need better pic?
The wires you need for the 12v are the ones at the top of the connector in your picture (with the white seals). The blanks on these connectors are blue plugs
White willy
Earth
2025 Ranger
Good find,and now another part inbound for mine 😂😂
My 2024 stx doesnt have a blank plug with a cover in it. The one i think it goes to has a plug into it with two wires coming out the cover side.
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update 20260508_112620
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update 20260508_112638
Is this the plug? What do those tiny wires do?
