2025 Ranger - Bed 12 Volt Outlet - Final Update
bigb
Tucson
2025 Ranger 2.7
For those of us who may have nothing (MY 25+ without convenience pkg), I'm going to assume there's no aftermarket solution premade for that panel space. Would have to fab something up ourselves?
No, go back and read post #21. I fabbed up my own but with the recent discovery of this low priced OEM part that's the way to go, it didn't exist when I did mine.
saxdogg
Jeremy
D/FW
2026 Ford Ranger XLT FX4
Does the panel everyone is adding have a standalone inverter built-in (just run power/ground to it) or would it only work if I had the under seat inverter shown earlier this evening?
Last question I think 😁
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
You need the inverter. The harness just sends 120v and 12v back. That is why it has an orange sleeve
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
@superj When was your Ranger built? Mine was Oct 2025. I wonder if they changed the wire mounting locations when they dropped the 12 volt socket.
I wonder if we could splice into the 12 volt cargo bed light?
mine was built February 2025, the connector is on the frame under truck. only 110V plug. but frame connector has 12v on truck side. 6 wires going into the plug, and only 4 coming out
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update 20250622_143142
DesertDweller
Arizona
2025 Ranger XLT 2.7L EcoBoost FX4
Eyeing Retirement
Mine is set up the same but I do have six wires behind the wheel. I neglected to count the wires behind the panel before I screwed it back into place. 🙄
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update IMG_2660
saxdogg
Jeremy
D/FW
Ok, took some photos under. March'26 build. I do have a orange wrapped loom coming down the frame rail. The orange tape stops before it branches off to the other pictured connectors that I think are the subject of y'all's posts. Seven wires in that one connector and one blank. ---shrugs--- 😁
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update 1000008221
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update 1000008222
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update 1000008223
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update 1000008224
pezdyspensr
New England
2024 Ranger STX
Mine has no inverter so i geuss i have to run a wire from the battery to the panel for power.
Did you end up doing this @superj? I know we have the same 24 STX. I didn't see any harness blanks anywhere either.
My plan, at the moment at least, is to use a method from another guy on here to put in a Curt tow harness to give myself 7pin tow (which I don't have yet) and some repinning from the OEM 4pin to give it power without running a wire to the battery, and at the same time tap off that power to get at least a 12v socket on my blank bed panel. Don't think there's much harm pulling from there - famous last words.
No, i didnt do it. We put it in my father in law's xlt since he only had the single power port.
pezdyspensr
New England
2024 Ranger STX
I'm just going to use the blank panel that's there on my '25 XL. Adding USB, a 12V SAE port, and a light so I can see when the cover is closed.
Will get the 12V from the trailer tow harness.
Did you end up getting this done? Would love to see how your solution worked, especially on rear connections. Tapped the tow wire, or ran 12v to the battery?
SLJ
The Finger Lakes
Not yet. All I've done is add magnetic USB rechargeable lights to the bed under the cover. The 12 volt and USB in the bed isn't a priority as I had them in my Maverick for three years and never used them. I've added them to the outside of of our camper which is when I would mostly use them.
GrimCop
Sean
2025 Ford Ranger
A couple quick questions before I buy the part. This is a pic of the underside of my 2025 XL 2wd with trailer tow. They come from the front in an orange and black wrapped harness. I do not have an inverter under the driver's seat. So, if I buy the ford part ( N1WZ-19A464-CC ) I know I won't have power to the 120v, but I should to the 12v right? And second do I just need to connect to both plugs (large and small) or just into the small one. New to all this, thanks!
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update 20260706_091633
the part will come with a single 8 pin connector.
you need to verify that there are six wires running into the 8 pin connector and the purple black wires carry the 12v and ground.
it you have that it as simple as plugging in the connector.
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update IMG_0558
GrimCop
Sean
2025 Ford Ranger
Thank you! Out of curiosity what is the smaller connector in my pic for then? The two side bed lights maybe (that I don't have lol)
Edit: I think the smaller plug is for the 120v if I had the inverter.
GrimCop
Sean
2025 Ford Ranger
And it does look like it'll work! I see purple and black :)
Ford Ranger 2025 Ranger - Bed 12 Volt Outlet - Final Update 20260706_102917
small connector is bed lights.
you have the wires for 120vac, just no inverter for it.
